I am trying to update from 105.5 to 107.7,
when I click update on supervisor it seems to be doing something:
It then restarts HA
and reverts to 105.5
I am running it on a virtual machine
Please help.
It then restarts HA
Please help.
Check the supervisor log for errors (at the bottom of the Supervisor/System page).
I get the following
20-04-08 17:26:41 INFO (MainThread) [supervisor.api.security] /snapshots access from cebe7a76_hassio_google_drive_backup
20-04-08 17:28:52 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.108.0
20-04-08 17:28:52 INFO (SyncWorker_4) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.105.5 to homeassistant/qemux86-64-homeassistant:0.108.0
20-04-08 17:28:52 INFO (SyncWorker_4) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.108.0.
20-04-08 17:31:53 INFO (SyncWorker_4) [supervisor.docker.interface] Stop homeassistant application
20-04-08 17:31:58 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 17:31:58 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 17:32:08 INFO (SyncWorker_4) [supervisor.docker.interface] Clean homeassistant application
20-04-08 17:32:08 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-04-08 17:32:09 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.108.0
20-04-08 17:32:34 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-04-08 17:33:03 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 17:33:03 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 17:33:49 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-04-08 17:35:08 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 17:35:08 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 17:39:13 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 17:39:13 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 17:43:51 WARNING (MainThread) [supervisor.homeassistant] Don't wait anymore of Home Assistant startup!
20-04-08 17:43:51 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
20-04-08 17:43:51 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.105.5
20-04-08 17:43:51 INFO (SyncWorker_7) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.108.0 to homeassistant/qemux86-64-homeassistant:0.105.5
20-04-08 17:43:51 INFO (SyncWorker_7) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.105.5.
20-04-08 17:43:57 INFO (SyncWorker_7) [supervisor.docker.interface] Stop homeassistant application
20-04-08 17:44:01 INFO (SyncWorker_7) [supervisor.docker.interface] Clean homeassistant application
20-04-08 17:44:01 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-04-08 17:44:02 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.105.5
20-04-08 17:44:18 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 17:44:18 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 17:44:27 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-04-08 17:46:28 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-04-08 17:46:53 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-04-08 17:46:53 INFO (MainThread) [supervisor.homeassistant] Successful run Home Assistant 0.105.5
20-04-08 17:46:53 INFO (SyncWorker_1) [supervisor.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:0.108.0']
My internal wifi address is on 192.168.68.xxx and I see it’s attempting a 172.xxx.xx.xx address, what are my options.
That’s the docker container’s network.
All the errors are related to snapshots, how can I sort this…
That’s not backup snapshots.
Try running the config check addon and make sure you don’t have any breaking changes that need addressing before you update.
I sorted the check config"
[21:42:31] INFO: Installed Home Assistant 0.108.0
[21:42:31] INFO: Making a copy of your configuration for checking...
[21:42:54] INFO: Checking your configuration against this version...
[21:48:15] INFO: Configuration check finished - no error found! :)
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
but I still have issues:
20-04-08 19:49:46 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.108.0
20-04-08 19:49:46 INFO (SyncWorker_6) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.105.5 to homeassistant/qemux86-64-homeassistant:0.108.0
20-04-08 19:49:46 INFO (SyncWorker_6) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.108.0.
20-04-08 19:53:12 INFO (SyncWorker_6) [supervisor.docker.interface] Stop homeassistant application
20-04-08 19:54:12 INFO (SyncWorker_6) [supervisor.docker.interface] Clean homeassistant application
20-04-08 19:54:13 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-04-08 19:54:14 INFO (SyncWorker_8) [supervisor.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.108.0
20-04-08 19:54:22 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 19:54:22 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 19:54:39 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-04-08 19:55:54 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-04-08 19:56:27 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 19:56:27 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 20:00:32 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 20:00:32 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 20:02:48 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
20-04-08 20:05:37 ERROR (MainThread) [supervisor.homeassistant] Error on call https://172.30.32.1:8123/api/states/binary_sensor.snapshots_stale: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
20-04-08 20:05:37 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-08 20:05:56 WARNING (MainThread) [supervisor.homeassistant] Don't wait anymore of Home Assistant startup!
20-04-08 20:05:56 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
20-04-08 20:05:56 INFO (MainThread) [supervisor.homeassistant] Update Home Assistant to version 0.105.5
20-04-08 20:05:56 INFO (SyncWorker_4) [supervisor.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.108.0 to homeassistant/qemux86-64-homeassistant:0.105.5
20-04-08 20:05:56 INFO (SyncWorker_4) [supervisor.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.105.5.
20-04-08 20:05:59 INFO (SyncWorker_4) [supervisor.docker.interface] Stop homeassistant application
20-04-08 20:06:03 INFO (SyncWorker_4) [supervisor.docker.interface] Clean homeassistant application
20-04-08 20:06:03 INFO (MainThread) [supervisor.homeassistant] Update pulse/client.config: /data/tmp/homeassistant_pulse
20-04-08 20:06:04 INFO (SyncWorker_8) [supervisor.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.105.5
20-04-08 20:06:29 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation in progress
20-04-08 20:08:19 INFO (MainThread) [supervisor.homeassistant] Home Assistant pip installation done
20-04-08 20:08:50 INFO (MainThread) [supervisor.homeassistant] Detect a running Home Assistant instance
20-04-08 20:08:50 INFO (MainThread) [supervisor.homeassistant] Successful run Home Assistant 0.105.5
20-04-08 20:08:50 INFO (SyncWorker_4) [supervisor.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:0.108.0']
Try rebooting the host then have another go.
Rebooted host and still having same problems
20-04-09 05:33:30 ERROR (MainThread) [supervisor.api.proxy] Error on API for request states/binary_sensor.snapshots_stale
20-04-09 05:38:08 WARNING (MainThread) [supervisor.homeassistant] Don't wait anymore of Home Assistant startup!
20-04-09 05:38:08 CRITICAL (MainThread) [supervisor.homeassistant] HomeAssistant update fails -> rollback!
