Hello at all
Since a few days my home assistant on Nuc shut down and not restart properly :
Problem of supervisor and so many module won’t start
In the observer I have this logs :
# Home Assistant observer
Supervisor: Disconnected
s6-rc: info: service s6rc-oneshot-runner: starting s6-rc: info: service s6rc-oneshot-runner successfully started s6-rc: info: service fix-attrs: starting s6-rc: info: service fix-attrs successfully started s6-rc: info: service legacy-cont-init: starting cont-init: info: running /etc/cont-init.d/udev.sh [14:27:49] INFO: Using udev information from host cont-init: info: /etc/cont-init.d/udev.sh exited 0 s6-rc: info: service legacy-cont-init successfully started s6-rc: info: service legacy-services: starting services-up: info: copying legacy longrun supervisor (no readiness notification) services-up: info: copying legacy longrun watchdog (no readiness notification) [14:27:49] INFO: Starting local supervisor watchdog... s6-rc: info: service legacy-services successfully started 24-01-19 14:27:50 INFO (MainThread) [__main__] Initializing Supervisor setup 24-01-19 15:27:50 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64 24-01-19 15:27:50 INFO (MainThread) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2023.12.1 24-01-19 15:27:50 INFO (MainThread) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network 24-01-19 15:27:50 ERROR (SyncWorker_0) [supervisor.docker.network] Can't link container to hassio-net: 500 Server Error for http+docker://localhost/v1.44/networks/4744a75db2d8c5a63087b401ac2331a41b40a9c58dfcc1c6ce0d35eeca4f1c2d/connect: Internal Server Error ("invalid endpoint settings: no configured subnet or ip-range contain the IP address 172.30.32.2") 24-01-19 15:27:50 CRITICAL (MainThread) [supervisor.supervisor] Can't setup Supervisor Docker container! 24-01-19 15:27:50 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state initialize 24-01-19 15:27:50 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete 24-01-19 15:27:50 INFO (MainThread) [__main__] Setting up Supervisor 24-01-19 15:27:50 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2 24-01-19 15:27:50 CRITICAL (MainThread) [supervisor.hardware.monitor] Not privileged to run udev monitor! 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus. 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1 24-01-19 15:27:50 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1 24-01-19 15:27:50 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled. 24-01-19 15:27:50 WARNING (MainThread) [supervisor.dbus.agent] No OS-Agent support on the host. Some Host functions have been disabled. 24-01-19 15:27:50 INFO (MainThread) [supervisor.host.services] Updating service information 24-01-19 15:27:50 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information 24-01-19 15:27:50 WARNING (SyncWorker_0) [supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server 24-01-19 15:27:50 INFO (MainThread) [supervisor.host.network] Updating local network information 24-01-19 15:27:51 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'} 24-01-19 15:27:51 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor 24-01-19 15:27:51 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json 24-01-19 15:27:51 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2023.11.0 24-01-19 15:27:51 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin 24-01-19 15:27:51 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_cli application 24-01-19 15:27:51 ERROR (SyncWorker_0) [supervisor.docker.network] Can't link container to hassio-net: 500 Server Error for http+docker://localhost/v1.44/networks/4744a75db2d8c5a63087b401ac2331a41b40a9c58dfcc1c6ce0d35eeca4f1c2d/connect: Internal Server Error ("invalid endpoint settings: no configured subnet or ip-range contain the IP address 172.30.32.5") 24-01-19 15:27:51 WARNING (SyncWorker_0) [supervisor.docker.manager] Can't attach hassio_cli to hassio-network! 24-01-19 15:27:51 INFO (MainThread) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2023.11.0 - 172.30.32.5 24-01-19 15:27:51 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 24-01-19 15:27:51 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin 24-01-19 15:27:51 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_dns application 24-01-19 15:27:51 ERROR (SyncWorker_0) [supervisor.docker.network] Can't link container to hassio-net: 500 Server Error for http+docker://localhost/v1.44/networks/4744a75db2d8c5a63087b401ac2331a41b40a9c58dfcc1c6ce0d35eeca4f1c2d/connect: Internal Server Error ("invalid endpoint settings: no configured subnet or ip-range contain the IP address 172.30.32.3") 24-01-19 15:27:51 WARNING (SyncWorker_0) [supervisor.docker.manager] Can't attach hassio_dns to hassio-network! 24-01-19 15:27:51 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2023.06.2 - 172.30.32.3 24-01-19 15:27:51 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf 24-01-19 15:27:51 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 24-01-19 15:27:51 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin 24-01-19 15:27:51 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_audio application 24-01-19 15:27:52 ERROR (SyncWorker_0) [supervisor.docker.network] Can't link container to hassio-net: 500 Server Error for http+docker://localhost/v1.44/networks/4744a75db2d8c5a63087b401ac2331a41b40a9c58dfcc1c6ce0d35eeca4f1c2d/connect: Internal Server Error ("invalid endpoint settings: no configured subnet or ip-range contain the IP address 172.30.32.4") 24-01-19 15:27:52 WARNING (SyncWorker_0) [supervisor.docker.manager] Can't attach hassio_audio to hassio-network! 24-01-19 15:27:52 INFO (MainThread) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4 24-01-19 15:27:52 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 24-01-19 15:27:52 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin 24-01-19 15:27:52 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_observer application 24-01-19 15:27:52 ERROR (SyncWorker_0) [supervisor.docker.network] Can't link container to hassio-net: 500 Server Error for http+docker://localhost/v1.44/networks/4744a75db2d8c5a63087b401ac2331a41b40a9c58dfcc1c6ce0d35eeca4f1c2d/connect: Internal Server Error ("invalid endpoint settings: no configured subnet or ip-range contain the IP address 172.30.32.6") 24-01-19 15:27:52 WARNING (SyncWorker_0) [supervisor.docker.manager] Can't attach hassio_observer to hassio-network! 24-01-19 15:27:52 INFO (MainThread) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6 24-01-19 15:27:52 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 24-01-19 15:27:52 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin 24-01-19 15:27:52 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning hassio_multicast application 24-01-19 15:27:52 INFO (MainThread) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2023.06.2 - Host 24-01-19 15:27:52 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 8 Home Assistant secrets 24-01-19 15:27:52 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version 2024.1.3 24-01-19 15:27:52 INFO (MainThread) [supervisor.os.manager] No Home Assistant Operating System found 24-01-19 15:27:52 WARNING (MainThread) [supervisor.homeassistant.core] Watchdog found Home Assistant failed, restarting... 24-01-19 15:27:52 INFO (SyncWorker_1) [supervisor.docker.manager] Starting homeassistant 24-01-19 15:27:53 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready 24-01-19 15:27:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/f5e830cd repository 24-01-19 15:27:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/19a172aa repository 24-01-19 15:27:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/core repository 24-01-19 15:27:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/15d21743 repository 24-01-19 15:27:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/a0d7b954 repository 24-01-19 15:27:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/5c53de3b repository 24-01-19 15:27:53 INFO (MainThread) [supervisor.store.git] Loading add-on /data/addons/git/45df7312 repository 24-01-19 15:27:53 INFO (MainThread) [supervisor.store] Loading add-ons from store: 84 all - 84 new - 0 remove 24-01-19 15:27:53 INFO (MainThread) [supervisor.addons.manager] Found 9 installed add-ons 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/hassio-addons/tasmoadmin/amd64 with version 0.29.1 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-ssh with version 9.8.1 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-mosquitto with version 6.4.0 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to thomasmauerer/samba-backup-amd64 with version 5.2.0 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to homeassistant/amd64-addon-configurator with version 5.7.0 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to zigbee2mqtt/zigbee2mqtt-amd64 with version 1.35.1-1 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to f5e830cd/amd64-addon-airsend with version 1.2 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/jcwillox/hassio-rclone-backup/amd64 with version 3.1.0 24-01-19 15:27:53 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Mosquitto broker is stopped, restarting... 24-01-19 15:27:53 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is stopped, restarting... 24-01-19 15:27:53 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Samba Backup is stopped, restarting... 24-01-19 15:27:53 INFO (SyncWorker_4) [supervisor.docker.manager] Cleaning addon_15d21743_samba_backup application 24-01-19 15:27:53 INFO (SyncWorker_8) [supervisor.docker.manager] Cleaning addon_core_mosquitto application 24-01-19 15:27:53 INFO (SyncWorker_5) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.interface] Attaching to ghcr.io/esphome/esphome-hassio with version 2023.12.7 24-01-19 15:27:53 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Rclone Backup is failed, restarting... 24-01-19 15:27:53 INFO (SyncWorker_3) [supervisor.docker.manager] Cleaning addon_19a172aa_rclone_backup application 24-01-19 15:27:53 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon ESPHome is failed, restarting... 24-01-19 15:27:53 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_5c53de3b_esphome application 24-01-19 15:27:53 INFO (MainThread) [supervisor.homeassistant.secrets] Request secret password_backup 24-01-19 15:27:53 INFO (MainThread) [supervisor.homeassistant.secrets] Request secret password_backup 24-01-19 15:27:53 INFO (MainThread) [supervisor.backups.manager] Found 101 backup files 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/esphome/esphome-hassio with version 2023.12.7 24-01-19 15:27:53 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-amd64 with version 1.35.1-1 24-01-19 15:27:54 INFO (MainThread) [supervisor.discovery] Loaded 2 messages 24-01-19 15:27:54 INFO (MainThread) [supervisor.ingress] Loaded 1 ingress sessions 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state setup 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.check] System checks complete 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete 24-01-19 15:27:54 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - privileged 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state setup 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete 24-01-19 15:27:54 INFO (MainThread) [__main__] Running Supervisor 24-01-19 15:27:54 CRITICAL (MainThread) [supervisor.core] System is running in an unhealthy state and needs manual intervention! 24-01-19 15:27:54 INFO (MainThread) [supervisor.jobs] 'OSManager.mark_healthy' blocked from execution, no Home Assistant OS available 24-01-19 15:27:54 INFO (MainThread) [supervisor.addons.manager] Phase 'initialize' starting 0 add-ons 24-01-19 15:27:54 INFO (MainThread) [supervisor.core] Supervisor reboot detected 24-01-19 15:27:54 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled 24-01-19 15:27:54 INFO (MainThread) [supervisor.core] Supervisor is up and running 24-01-19 15:27:54 INFO (MainThread) [supervisor.host.info] Updating local host information 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system 24-01-19 15:27:54 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon 24-01-19 15:27:54 INFO (MainThread) [supervisor.homeassistant.secrets] Request secret password_backup 24-01-19 15:27:54 INFO (MainThread) [supervisor.host.services] Updating service information 24-01-19 15:27:54 INFO (MainThread) [supervisor.host.network] Updating local network information 24-01-19 15:27:54 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on ghcr.io/jcwillox/hassio-rclone-backup/amd64 with version 3.1.0 24-01-19 15:27:54 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on thomasmauerer/samba-backup-amd64 with version 5.2.0 24-01-19 15:27:54 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on homeassistant/amd64-addon-mosquitto with version 6.4.0 24-01-19 15:27:54 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information 24-01-19 15:27:54 INFO (MainThread) [supervisor.host.manager] Host information reload completed 24-01-19 15:27:57 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Zigbee2MQTT is failed, restarting... 24-01-19 15:27:57 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning addon_45df7312_zigbee2mqtt application 24-01-19 15:27:57 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token 24-01-19 15:27:57 INFO (MainThread) [supervisor.docker.addon] Starting Docker add-on zigbee2mqtt/zigbee2mqtt-amd64 with version 1.35.1-1 24-01-19 15:27:58 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant Core state changed to NOT_RUNNING
I have try a reboot of the Nuc without success …Always the same problem
I am not geek professionnal of HA for understand the problem
Does anyone could help me ?
