Might start off by saying that I’m a complete beginner on this whole Home Assistant “thing”. And , English is not my native language, so bear with me. And if this is the dumbest question ever asked here, or already answered in some form, sorry.
So, I have an old Animus Home that no longer is “supported” so I wanted to house a Home Assistant installation on it instead. I have installed Home Assistant to a 32gb sd card, and everything seems to run okay after the initial setup. I can for an example find my Philips Hue bridge and it works like a charm.
The “PROBLEM” is that I want to use all my 433mhz wall switches to control lamps connected to them. I think there is “build in” 433mhz antennas on the Animus Home board, but I don’t know how to get it to work in Home Assistant. I have googled my brains out, but as the complete beginner that I am I don’t understand how to “fix” it.
It seems like people have to buy an external 433mhz transmitter/receiver? to get 433mhz to work in/with Home Assistant and Raspberry Pi:s (and the Animus have a very pi-like board). The thing is, that I mentioned earlier, that I think those “things” are already “built in” to the board of the Animus Home as 433mhz worked with the Animus Home when running their own “OS”. And when opening up the Animus I can clearly see an antenna attached to the board.
What am I missing? Care to provide some help and explain to a complete beginner in Home Assistant and on Pi:s.
Sorry for the long post, and thanks!
