Hey there
I would love, if someone could explain me, how I can run HA on a Banana Pi. I tried it with the manual installation and Hassbian and so on, but it won’t work for me
Hey there
Hello! By manual installation, do you mean through pip? What operating system is your Banana running? (never thought I’d ask that)
I have tried it on Lubuntu. And I have done the installation with the video tutorial of Bruh, like the very first one. Also tried it with Hassbian
If you are using armbian then take a look at this PR:
So i will install those python packages and then I have to follow what instruction? And what OS do I have to use?
Hello everyone,
In the last 3 years I used an BananaPi M1 for my home automation and monitoring, Imade myself the interface, didn’t used HA or any other software, just pure PHP/MySQL and HTML using responsive design, it looks perfect on both desktop and mobile.
Now, for a new apartment that we want to rent, I want to use HA for monitoring and automation, I also wanted to use the same BananaPi as it seems is very reliabl, with a SSD plugged in the embeded SATA port, this is the only reason I wanted to use BananaPi, as it already has an SATA port , no need for any adapters. Mine still boots from the SD, it’s no problem, but all the data is saved on the SSD.
So, can I use an BananaPi (BPI-M2 Banana Pi M2 Berry A7) with Armbian OS for HA?
Does HA needs an powerfull more CPU? Should I go for Raspi 3 with SSD on USB. Can I have the OS installed on the SSD? I really preffer directly on the SATA port, but unfortunatelly there is no Raspbbery with SATA port
Thank you…!
I haven’t got HA to work with my BananaPi… I’ve almost tried everything I could find.
I would go with a rpi3 or rpi4 if you want. If you really need the extra space, go for a nuc or any other linux server. You don’t want to install HA manually (that isn’t supported anymore anyways), you want to install hassio directly and that doesn’t work with a BananaPi.
@Paytrix thank you for your reply.
Anyone knows if I will get the NanoPi M4 with the aditional SSD board , can I install Home Assistant ?
https://www.friendlyarm.com/index.php?route=product/product&product_id=234
find this post after blowing off sime dust on my M2U.
I have managed to upgrade it to Ubuntu 20, and made docker installation on SSD.
Stayed on kernel 3.10 though, as I’m on “linux user” level
Regards
Jan
