Home assistant on Ihost freezing and freezing router
Hello guys,
I need your help!
I am running Ha on ihost 4gb ,
Everyday it completely freezes and also freezes my router ( internet connection lost to my phones)
This is a log of what i could retrieve from HA the issue started about 1:00 AM
Cant access to the HA via IP until i restart manually. Its frustrtating it keeps happening.
Please help
Home Assistant Core
Loading log…
2026-08-10 23:55:33.458 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:33.538 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:33.540 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:33.916 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:33.931 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:34.245 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:34.247 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:37.157 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:37.158 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:50.664 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:50.871 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:50.873 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:50.884 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:50.886 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:50.965 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:55:52.779 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:11.635 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:13.870 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.137 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.305 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.320 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.334 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.392 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.406 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.416 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.432 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.434 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.692 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.694 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.829 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:22.843 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:23.112 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:23.130 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:23.141 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:23.155 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:23.165 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:28.047 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:28.049 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:28.051 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:28.111 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:28.718 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:56:28.733 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.370 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.372 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.374 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.393 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.427 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.441 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.450 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.460 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.470 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.491 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.503 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.520 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.529 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.542 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.544 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.559 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.569 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.581 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.592 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.604 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.616 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.629 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.631 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:19.632 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:27.899 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:27.914 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:28.064 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:34.409 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-10 23:57:37.212 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-11 00:04:16.436 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:17:05.115 WARNING (MainThread) [homeassistant.components.websocket_api.http.connection] [1936041176] Mohamad cherkawi from 127.0.0.1 (Mozilla/5.0 (Linux; Android 11; SM-T515 Build/RP1A.200720.012; wv) AppleWebKit/537.36 (KHTML, like Gecko) Version/4.0 Chrome/87.0.4280.141 Safari/537.36 Home Assistant/2026.6.5-22884 (Android 11; SM-T515)): Disconnected: Received error message during command phase: No PONG received after 27.5 seconds
2026-08-11 00:20:21.773 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:24:02.127 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:31:07.723 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:33:49.387 ERROR (MainThread) [frontend.js.modern.202511051] Failed to format translation for key ‘ui.components.language-picker.no_match’ in language ‘en-GB’. Error: The intl string context variable “term” was not provided to the string “No languages found for {term}”
2026-08-11 00:34:08.049 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:37:08.377 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:40:08.676 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:41:10.116 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:44:12.516 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:47:13.819 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:50:15.202 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
2026-08-11 00:54:05.124 ERROR (Thread-7) [pychromecast.socket_client] [Living Room TV(192.168.1.159):8009] Failed to connect to service HostServiceInfo(host=‘192.168.1.159’, port=8009), retrying in 5.0s
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
Sorry can’t help with your issue, but Home Assistant hasn’t been supported on the 32bit ARM 7 processor for a bit now. Might be time to ditch the iHost, can only imagine if you fix this something else will break soon.
Thank you, What do you think is the ultimate replacement
That question has been asked many times and you’ll get different answers. If you want it simple buy a Home Assistant Green. Personally I’d suggest either a used mini desktop PC or a new Intel N100 or N150 PC. I’d avoid the Raspberry Pi, an Intel PC is better/cheaper on everything apart from power consumption in my opinion.
This was a bug which was fixed in 2025.12. Unfortunately for you, 2025.12 is also the release which killed off 32-bit support, so at best your HA version is 2025.11 or older.
Like the others said, ditch the iHost & get something which doesn’t require 9 month old (and counting) firmware to run.
