Home Assistant on macOS using virtualbox
new home assistant install on macos using virtualbox. once installed I access IP address:8123 from browser and create user, password, set language etc, then on the next screen (blue floating shapes with Home Assistant logo) it stops. won’t go any further. I can access ha command line and run commands like core check and all looks good. suggestions?
Version: 2023.5.1
Virtualbox 7.0.8
Mac 11.7.6
installed again same config but used ubuntu 64bit as the version of linux vs. linux 2.6/3.x/4.x/5.x 9 (64bit) and it works.
