I have a Pi 4 with Home Assistant - everything has been running smoothly for years. Now I wanted to set up Home Assistant for my friend on a Pi 5, it worked, but after about 2 weeks I could no longer access the UI. The whole time the system was just on the loading data screen, it has nothing to do with my browser (I tried everything), but devices and automations still work. I couldn’t do anything other than unplug the Raspberry and after that the SD card was no longer partitioned, nothing, an error in the superblock or something. Now I installed Home Assistant again, after 3 days the same error again, all devices still work but no access via the UI. In the terminal I was shown a “failed to get inode” and a “Buffer i/O error on dev mmclbk0p3, logial block 24239, async page read” error and a few variations of that, nothing else, I couldn’t enter anything using the mouse/keyboard either. Now unplugged again, SD empty…I really only had HACS (without installing anything from it), Cloudflared and a few integrations like Philips Hue and Bosch activated. What can I do? I have to reinstall it again, what should I do differently?
Check that SD -it sounds like it’s having issues.
That said,if deploying new… I’d absolutely do it on an SSD instead much better for purpose.
You may also want to check your IP address to make sure it hasn’t changed. I upgraded recently and my new RaspberryPi wanted to use another IP address on my lan and I had to adjust a few other things.
same issue here
