Home Assistant on Rasbian not installing
Hi there,
So niether Hass.io or hassbian has worked for me to install HomeAssistant (I am on an older pi) so I am trying to do it the old fashion way using the steps here: https://www.home-assistant.io/docs/installation/raspberry-pi/
I get all the way down to the second to last step without issue:
(homeassistant) homeassistant@raspberrypi:/srv/homeassistant $ pip3 install homeassistant
When it all goes wrong.
The errors I am getting look like this (everything from β€œException” and below is error):
 Downloading https://files.pythonhosted.org/packages/30/4e/27c34b62430286c6d59177a0842ed90dc789ce5d1ed740887653b898779a/pytz-2018.5-py2.py3-none-any.whl (510kB)
100% |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 512kB 107kB/s
Collecting PyJWT==1.6.4 (from homeassistant)
Exception:
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
chunked=chunked)
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 350, in _make_request
self._validate_conn(conn)
 File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 837, in _validate_conn
conn.connect()
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py", line 323, in connect
ssl_context=context)
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/ssl_.py", line 324, in ssl_wrap_socket
return context.wrap_socket(sock, server_hostname=server_hostname)
  File "/usr/lib/python3.5/ssl.py", line 385, in wrap_socket
_context=self)
  File "/usr/lib/python3.5/ssl.py", line 760, in __init__
self.do_handshake()
  File "/usr/lib/python3.5/ssl.py", line 996, in do_handshake
self._sslobj.do_handshake()
  File "/usr/lib/python3.5/ssl.py", line 641, in do_handshake
ConnectionResetError: [Errno 104] Connection reset by peer
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py", line 215, in main
status = self.run(options, args)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py", line 353, in run
wb.build(autobuilding=True)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/wheel.py", line 749, in build
self.requirement_set.prepare_files(self.finder)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 554, in _prepare_file
require_hashes
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_install.py", line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
 File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 568, in _get_pages
page = self._get_page(location)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 792, in get_page
"Cache-Control": "max-age=600",
 File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
return self.request('GET', url, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/download.py", line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
timeout=timeout
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen
_stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment
total -= 1
 TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
I googled around on this, but cant seem to find anyone having the same problem. I retried the command a few times and the same thing happens. Does anyone have any suggestions?
Thank you so much!
Brian
This is a network error. It could be your internet connection, or the pypi server could be overloaded. Try again later.
