Hi ! 6 months ago I discovered Home Assistant while I was looking for new projects to do. Then I tried to use a VM, but I decided that for the final project I wanted to use a Raspberry Pi. I’ve been looking for one since then, and an option that came up recently is a Raspberry Pi 3A+, 512MB RAM for less than 30 euros. A few Raspberry Pi 4Bs have also appeared, but they are at least 150-200 euros, which is too much. What do you think? Can I integrate Home Assistant with Raspberry Pi 3A+? Thank you very much!
Hi @SPetru as per this github issue logged for HAOS the Pi 3A+ only has 512MB RAM and this causes the system to become very unresponsive, HAOS 64bit really needs upwards of 2GB, so the recommended PI to use is the 4 with 4GB
Although I have my HAOS running on a Raspberry Pi 4 Model B - 1GB RAM purchased in Feb this year
