Just purchased a UPS for my router and MQTT server. I also purchased a small power bank for the rPi running home assistant.
Now when power goes down, a router that is situated with the rPi will go down as well. So I was contemplating using WiFi as a back-up for my rPi. Would that work?
Would like to primary run hard-wired, as not to congest my wifi…
I just set up WiFi and it seems to be working as I want. LAN is the primary, WiFi is secondary. When LAN is lost, WiFi takes over. I added the WLAN interface to my overview and little data is being used there.
Would you be willing to share a link to the power bank you are using for the Pi? This has been discussed here a number of times, seems many don’t charge and power a device at the same time.
Also did you do something to setup the wifi as a failover? Having both wired and wifi on my Pi caused havoc for my Pi as it was actually connecting the wired and wireless at the same time.
Got mine today, doesn’t seem to be working as intended … It blinks for about a second when I unplug AC. It does charge while using it. Will fully charge and do some more tests.
Regarding the power bank, I had that same issue too.
After doing lots and lots of Googling, I decided to get this GeekWorm X728 UPS & Power Management Board which charges and powers the Pi at the same time.
It isn’t a very pretty solution, but it works very well for me.
