Home Assistant on Synology that doesn't support Docker
I’ve followed https://www.home-assistant.io/docs/installation/synology/ to install HA on a Synology without Docker (can’t remember the model, an ARM processor).
When I run sudo /volume1/homeassistant/hass-daemon start I get “Starting Home Assistant…” and then it drops me to the shell and… nothing. I run hass-daemon status and it says “Home Assistant is not running”. How can I troubleshoot where the process is failing? It does create a home-assistant.pid file…
