Home Assistant on Ubuntu on Windows 10 Errors
I have installed Home-Assistant on the Ubuntu on Windows 10. To clarify, this is not a VM. Everything seems to be working correctly (though I have yet to test my Z-Wave USB Stick on it yet, except as soon as I login to the UI, this error occurs. What is it and is there anything I can do?
16-09-07 16:47:30 homeassistant.core: BusHandler:Exception doing job
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/core.py", line 852, in job_handler
    func(*args)
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/event.py", line 179, in pattern_time_change_listener
    action(now)
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity_component.py", line 180, in _update_entity_states
    entity.update_ha_state(True)
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/helpers/entity.py", line 154, in update_ha_state
    self.update()
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/command_line.py", line 113, in update
    payload = str(self._query_state())
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/command_line.py", line 107, in _query_state
    return CommandSwitch._query_state_value(self._command_state)
  File "/usr/local/lib/python3.4/dist-packages/homeassistant/components/switch/command_line.py", line 70, in _query_state_value
    return_value = subprocess.check_output(command, shell=True)
  File "/usr/lib/python3.4/subprocess.py", line 607, in check_output
    with Popen(*popenargs, stdout=PIPE, **kwargs) as process:
  File "/usr/lib/python3.4/subprocess.py", line 859, in __init__
    restore_signals, start_new_session)
  File "/usr/lib/python3.4/subprocess.py", line 1395, in _execute_child
    restore_signals, start_new_session, preexec_fn)
OSError: [Errno 12] Cannot allocate memory
Hey @scottocs,
Reading the rest of the article you’ll fine a limitations section. I have the feeling you’re hitting an scenario that is not fully supported or is part of he development cycle still.
Did this ever worked??
Everything appeared to work, except it couldn’t connect to any USB devices I had attached to my Windows computer. And whatever error this is happened, but I didn’t see anything visually wrong.
Hi, I am installed Home assistant on window 10 And I get an error on it and I am unable to use it.Your above discussion is really help me to solve the error.One error 0xc000000f that can damage the speed of system I got an solution from the link.
