Home Assistant OS 12.4 VM installation fails
Spinning up a new VM in unraid using the [KVM/Proxmox] (.qcow2) image as per
haos_ova-12.4.qcow2.xz
VMboots and can access the web :8123 to observe install detail/logs.
Error installing Home Assistant
An error occured while installing Home Assistant, check the logs below for more information.
(side issue typo there on occured/occurred)
1 - 2024-07-06_14-59-10
2- 2024-07-06_14-59-26
3-32024-07-06_14-59-37
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
[__main__] Initializing Supervisor setup
[supervisor.docker.network] Can't find Supervisor network, creating a new network
[supervisor.bootstrap] Setting up coresys for machine: qemux86-64
[supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2024.06.0
[supervisor.docker.supervisor] Connecting Supervisor to hassio-network
[supervisor.resolution.evaluate] Starting system evaluation with state initialize
[supervisor.resolution.evaluate] System evaluation complete
[__main__] Setting up Supervisor
[supervisor.api] Starting API on 172.30.32.2
[supervisor.hardware.monitor] Started Supervisor hardware monitor
[supervisor.dbus.manager] Connected to system D-Bus.
[supervisor.dbus.agent] Load dbus interface io.hass.os
[supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
[supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
[supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
[supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
[supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
[supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
[supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
[supervisor.host.services] Updating service information
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.sound] Can't update PulseAudio data: Failed to connect to pulseaudio server
[supervisor.host.network] Updating local network information
[supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
[supervisor.docker.monitor] Started docker events monitor
[supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2024.05.0
[supervisor.plugins.cli] Starting CLI plugin
[supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2024.05.0 - 172.30.32.5
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0
[supervisor.plugins.dns] Starting CoreDNS plugin
[supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2024.04.0 - 172.30.32.3
[supervisor.plugins.dns] Updated /etc/resolv.conf
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0
[supervisor.plugins.audio] Starting Audio plugin
[supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2023.12.0 - 172.30.32.4
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0
[supervisor.plugins.observer] Starting observer plugin
[supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2023.06.0 - 172.30.32.6
[supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: []
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0
[supervisor.plugins.multicast] Starting Multicast plugin
[supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2024.03.0 - Host
[supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
[supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
[supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
[supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
[supervisor.homeassistant.core] Using preinstalled landingpage
[supervisor.homeassistant.core] Starting HomeAssistant landingpage
[supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
[supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
[supervisor.os.manager] Detect Home Assistant Operating System 12.4 / BootSlot A
[supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
[supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
[supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
[supervisor.store.git] Can't clone https://github.com/esphome/home-assistant-addon repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/esphome/home-assistant-addon /data/addons/git/5c53de3b
stderr: 'Cloning into '/data/addons/git/5c53de3b'...
fatal: unable to access 'https://github.com/esphome/home-assistant-addon/': Recv failure: Connection reset by peer
[supervisor.store] Can't retrieve data from https://github.com/esphome/home-assistant-addon due to
[supervisor.resolution.module] Create new suggestion execute_remove - store / 5c53de3b
[supervisor.resolution.module] Create new issue fatal_error - store / 5c53de3b
[supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Recv failure: Connection reset by peer
[supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
[supervisor.resolution.module] Create new suggestion execute_remove - store / a0d7b954
[supervisor.resolution.module] Create new issue fatal_error - store / a0d7b954
[supervisor.store.git] Can't clone https://github.com/home-assistant/addons repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules -- https://github.com/home-assistant/addons /data/addons/core
stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/addons/': Recv failure: Connection reset by peer
[supervisor.store] Can't retrieve data from core due to
[supervisor.resolution.module] Create new suggestion execute_remove - store / core
[supervisor.resolution.module] Create new issue fatal_error - store / core
[supervisor.store] Loading add-ons from store: 0 all - 0 new - 0 remove
[supervisor.addons.manager] Found 0 installed add-ons
[supervisor.backups.manager] Found 0 backup files
[supervisor.discovery] Loaded 0 messages
[supervisor.ingress] Loaded 0 ingress sessions
[supervisor.resolution.check] Starting system checks with state setup
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.checks.base] Run check for detached_addon_removed/addon
[supervisor.resolution.checks.base] Run check for detached_addon_missing/addon
[supervisor.resolution.checks.base] Run check for disabled_data_disk/system
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state setup
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - setup
[__main__] Running Supervisor
[supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
[supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
[supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
[supervisor.supervisor] Update Supervisor to version 2024.06.2
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2024.06.2.
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.06.2: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.06.2&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded (Client.Timeout exceeded while awaiting headers)")
[supervisor.resolution.module] Create new issue update_failed - supervisor / None
[supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.06.2: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.06.2&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded (Client.Timeout exceeded while awaiting headers)")
CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
[supervisor.addons.manager] Phase 'initialize' starting 0 add-ons
[supervisor.addons.manager] Phase 'system' starting 0 add-ons
[supervisor.addons.manager] Phase 'services' starting 0 add-ons
[supervisor.core] Skipping start of Home Assistant
[supervisor.addons.manager] Phase 'application' starting 0 add-ons
[supervisor.misc.tasks] All core tasks are scheduled
[supervisor.core] Supervisor is up and running
[supervisor.homeassistant.core] Home Assistant setup
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.1
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.7.1.
[supervisor.host.info] Updating local host information
[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
[supervisor.host.manager] Host information reload completed
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.1: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.7.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": context deadline exceeded (Client.Timeout exceeded while awaiting headers)")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.1: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.7.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled (Client.Timeout exceeded while awaiting headers)")
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.1: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.7.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/qemux86-64-homeassistant/manifests/2024.7.1": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fqemux86-64-homeassistant%3Apull&service=ghcr.io": context deadline exceeded (Client.Timeout exceeded while awaiting headers)")
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.1: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.7.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/qemux86-64-homeassistant/manifests/2024.7.1": read tcp 192.168.140.14:54210->20.248.137.52:443: read: connection reset by peer")
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.1: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.7.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/qemux86-64-homeassistant/manifests/2024.7.1": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fqemux86-64-homeassistant%3Apull&service=ghcr.io": net/http: TLS handshake timeout")
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.7.1: 500 Server Error for http+docker://localhost/v1.45/images/create?tag=2024.7.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Head "https://ghcr.io/v2/home-assistant/qemux86-64-homeassistant/manifests/2024.7.1": Get "https://ghcr.io/token?scope=repository%3Ahome-assistant%2Fqemux86-64-homeassistant%3Apull&service=ghcr.io": net/http: request canceled (Client.Timeout exceeded while awaiting headers)")
May have resolved this (suspect DNS) but will report back once confirmed.
I have new unraid server that I copied a ubuntu VM virtual disk running pihole.
The new server was not set with static IP/DNS settings so was not getting an IP until after fully booted.
I stopped the array and set stataic IP with google DNS server 8.8.8.8 and started the array.
The ubuntu VM is/was running fine.
I experience a very similar issue firing up a new 11.1 HAOS image.
I then tested the 12.4 on my old unraid server and it worked fine so that pointed back to the new unraid sever as the issue.
I’ve just rebooted the new unraid server and it go through the full install ok.
Will run again shortly and report back.
Can confirm the unraid DNS change required a reboot to take effect.
Install from a fresh qcow2 completes fine.
Perhaps some room there for better error messages.
para mim deu problema tambem no google chrome, ai acessei via firefox e deu certo
English please
