I am running Home Assistant OS on my Intel Nuc esxi host. I have allocated 6 CPUs to that VM.
When I look at glances, CPU usage the HA OS is very low. But CPU usage for dockers is near 80-90% (I am running Frigate addon so high CPU is expected).
I suspect that docker on Home Assistant OS is not using all 6 CPUs - how do I check that ?
And if in fact docker is only using 1 CPU, how do I tell it to use all of them?
Andre
That doesn’t mean much by itself.
- By HA OS, do you mean the Homeassistant process?
- By “dockers”, do you mean addon containers, or…?
- You see processes running inside docker. If the dockerd process (docker itself) takes 80/90% of a CPU, you have a problem.
- You don’t say if it’s the overall CPU usage or per process one. Per process, 100% = 1 CPU, thus you would have > 100% for processes using multiple CPU’s.
Now, it could be a specific way of displaying of glances, but then it doesn’t tell me much
