Is there a guide for getting Home Assistant OS to work with an external NGINX docker for Cloudflare Origin Certs?
I already have NGINX running elsewhere so ports 443 & 80 are taken on my network so i don’t think I can run 2 instances of NGINX on the network. Im looking for the Cloudflare Origin Cert to work as my Home Assistant was exposed over DuckDNS and was getting daily brute force attempts. My Ubiquiti IDS is seeing attempts on my network as well so the less visibility out there the better without having to go down a VPN route.
I’m getting mixed results when i try to use the external NGINX docker, like being able to see the login page but it fails login after 2fa and the loop restarts, or the page being visible on my web browser on my mobile but the Home Assistant Android APP not seeing the server running.
