Home Assistant OS - Host
I’m posting because i use a Giada Fanless mini PC and when i need to restart the host, for example for Home Assistant OS update, it never restarts. Stucks when the motherboard needs to be rebooted. I need to turn it off manualy and turn on again.
You need to update kernel for this PC, probably its not used by many people and it’s not a priority for you but here’s a tip for a next future update.
PC in question:
http://www.giadatech.com/index/product/detail/aid/805.html
Thanks for your great work. I use this for some time and its awesome, including Home Assistant Cloud.
You should open up an issue for this in the operating-system repository on github
were you able to solve this? I’m looking at a used Giada DE67 to replace my failing RPI4.
BTW I bought the Giada and it’s running Proxmox flawlessly, HAOS VM, currently on day 73 of uptime with no issues whatsoever.
