I’ve installed Home Assistant OS directly on a NUC. I was hoping to mount a second drive to use as storage for Plex content (exposed through the Plex Media Server add-on).
Is it possible to mount a second drive in HAOS and make it available to the Plex add-on?
HAOS can see both my drives, but only /dev/sda (where I installed it) has active mounts.
In the ‘docker’ ssh, I created /media/space but couldn’t mount from within the docker container (understandably).
From the host root (login at ha prompt on the physical box) I found this directory in /mnt/data/supervisor/media/space and was able to mount my drive at it with: mount /dev/sdb1 /mnt/data/supervisor/media/space
The Plex media player add-on finds this at /media/space and serves content which I add there.
Is this likely to cause me issues? It seems to be working perfectly.
However, I haven’t found a way to persist it across restarts.
/etc/fstab is read-only
there’s no crontab
I can’t create a systemd service because the file system is read-only
Is there any way to run mount /dev/sdb1 /mnt/data/supervisor/media/space automatically on startup?
