Home Assistant OS not starting
since I could not find any solution, I try it with a new topic.
The issue is that I have bought a server (Dell Poweredge R330) to install HA OS (please avoid discussions about being necessary or not, I would like to understand the issue and get it up and running. If the setup stays like this is another story).
I can install whatever OS I want (tried with Ubuntu & Debian), they all boot normal.
But when I install HA OS, it stays on this line
I read, that the first boot could take some time, but even after one night, nothing has changed.
I turned of RAID (as I wanted to setup Raid0 for Frigate) but this did not helped.
Server:
Dell Poweredge R330
1x Intel(R) Xeon(R) CPU E3-1270 v5 @ 3.60GHz
1x 16GB ECC RAM
2x 1TB SAMSUNG
1x Broadcom Gigabit Ethernet BCM5720
Could be a driver issue.
Do you have this connected to an Avocent KVM switch?
If so, try just using a standard keyboard, mouse and display.
thanks, at least now something has changed.
You can disable Keyboard & Mouse in iDrac.
It stops now at clocksource tsc
Look like i have a same issue
did you get it fixed
no, unfortunately not…
