Home Assistant OS shutdown indicator
I am currently running Home Assistant OS (11.1) and Home Assistant Core (2023.11.3) on a Raspberry Pi 4 and would like to know if a particular feature that is available when running Raspberry Pi OS is also available when running Home Assistant OS.
Raspberry Pi OS allows you to configure a GPIO pin to signal when the Raspberry Pi has fully shut down. Typically I attach an LED to the specified GPIO pin and when the LED lights up I know it is safe to power down the Raspberry Pi. To enable this feature, you add the following to the /boot/config.txt file:
dtoverlay=gpio-poweroff,gpiopin=25,active_high
This is extremely handy when working with ‘headless’ Raspberry Pi’s.
So, is it possible to enable this feature under Home Assistant OS?
There is a way. It’s in the DEV docs someplace. You would have to dig around for it.
That’s great news! I hope I can locate that bit of info.
-Wes
I think you missed the point.
I found some info Googling and it makes it sound like I’d have to modify and recompile the OS. Do you agree?
I used option 1, but the logic was reversed. LED off, safe to turn off
https://forums.raspberrypi.com/viewtopic.php?t=267032#p1622869
