I try to create a server for HA with proxmox and after everything works I go to the site and it gets stuck on the blue dot (Preparing Home Assistant). I do not know what to do. I tried changing the server’s and router’s dns, and it still does not work, I have enough storage. Anyone know what the problem is and can help me please.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] udev.sh: executing...
[08:02:47] INFO: Using udev information from host
[cont-init.d] udev.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[08:02:47] INFO: Starting local supervisor watchdog...
22-01-08 08:02:48 INFO (MainThread) [__main__] Initializing Supervisor setup
22-01-08 08:02:48 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
22-01-08 08:02:49 INFO (MainThread) [supervisor.bootstrap] Initializing Supervisor Sentry
22-01-08 08:02:49 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: qemux86-64
22-01-08 08:02:49 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor homeassistant/amd64-hassio-supervisor with version 2021.12.2
22-01-08 08:02:49 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
22-01-08 08:02:49 WARNING (SyncWorker_0) [supervisor.docker.interface] Can't find homeassistant/amd64-hassio-supervisor for cleanup
22-01-08 08:02:49 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
22-01-08 08:02:49 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-01-08 08:02:49 INFO (MainThread) [__main__] Setting up Supervisor
22-01-08 08:02:49 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
22-01-08 08:02:49 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
22-01-08 08:02:49 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface io.hass.os
22-01-08 08:02:49 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.systemd1
22-01-08 08:02:49 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.login1
22-01-08 08:02:49 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.hostname1
22-01-08 08:02:49 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.timedate1
22-01-08 08:02:49 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface org.freedesktop.NetworkManager
22-01-08 08:02:49 INFO (MainThread) [supervisor.dbus.manager] Load dbus interface de.pengutronix.rauc
22-01-08 08:02:49 INFO (MainThread) [supervisor.host.info] Updating local host information
22-01-08 08:02:49 INFO (MainThread) [supervisor.host.services] Updating service information
22-01-08 08:02:49 INFO (MainThread) [supervisor.host.network] Updating local network information
22-01-08 08:02:50 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-01-08 08:02:50 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-01-08 08:02:50 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
22-01-08 10:02:50 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2021.09.0'>]
22-01-08 10:02:50 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2021.09.0
22-01-08 10:02:50 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
22-01-08 10:02:51 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2021.09.0 - 172.30.32.5
22-01-08 10:02:51 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2021.06.0'>]
22-01-08 10:02:51 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2021.06.0
22-01-08 10:02:51 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
22-01-08 10:02:51 INFO (SyncWorker_0) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2021.06.0 - 172.30.32.3
22-01-08 10:02:51 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
22-01-08 10:02:51 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2021.07.0'>]
22-01-08 10:02:51 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2021.07.0
22-01-08 10:02:51 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
22-01-08 10:02:52 INFO (SyncWorker_0) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2021.07.0 - 172.30.32.4
22-01-08 10:02:52 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
22-01-08 10:02:52 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
22-01-08 10:02:52 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
22-01-08 10:02:52 INFO (SyncWorker_0) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0 - 172.30.32.6
22-01-08 10:02:52 INFO (SyncWorker_1) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2021.04.0'>]
22-01-08 10:02:52 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2021.04.0
22-01-08 10:02:53 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
22-01-08 10:02:53 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2021.04.0 - Host
22-01-08 10:02:53 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-01-08 10:02:53 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
22-01-08 10:02:53 INFO (SyncWorker_0) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/qemux86-64-homeassistant
22-01-08 10:02:53 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/qemux86-64-homeassistant found.
22-01-08 10:02:53 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
22-01-08 10:02:53 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
22-01-08 10:02:53 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
22-01-08 10:02:53 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
22-01-08 10:02:53 INFO (SyncWorker_1) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/qemux86-64-homeassistant with version landingpage
22-01-08 10:02:53 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 7.1 / BootSlot A
22-01-08 10:02:53 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
22-01-08 10:02:53 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
22-01-08 10:02:56 INFO (MainThread) [supervisor.store] Loading add-ons from store: 62 all - 62 new - 0 remove
22-01-08 10:02:56 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
22-01-08 10:02:56 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
22-01-08 10:02:56 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
22-01-08 10:02:56 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-01-08 10:02:56 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
22-01-08 10:02:56 INFO (MainThread) [__main__] Running Supervisor
22-01-08 10:02:56 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
22-01-08 10:02:56 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
22-01-08 10:02:56 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
22-01-08 10:02:56 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
22-01-08 10:02:56 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
22-01-08 10:02:56 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
22-01-08 10:02:56 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
22-01-08 10:02:56 INFO (MainThread) [supervisor.core] Supervisor is up and running
22-01-08 10:02:56 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
22-01-08 10:02:56 INFO (MainThread) [supervisor.host.info] Updating local host information
22-01-08 10:02:56 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.8
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-01-08 10:02:56 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2021.12.8.
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
22-01-08 10:02:56 ERROR (MainThread) [supervisor.utils] Can't execute check_trust while a task is in progress
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
22-01-08 10:02:56 INFO (MainThread) [supervisor.host.services] Updating service information
22-01-08 10:02:56 INFO (MainThread) [supervisor.host.network] Updating local network information
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-01-08 10:02:56 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-01-08 10:02:56 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-01-08 10:03:08 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.8: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.8/json: Not Found ("no such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.8: No such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2021.12.8")
22-01-08 10:03:08 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
