I just realised that home assistant is still in the winter time, when I look at the log and everything, the system is 1hour behind:
21-03-30 23:29:44
Actual time 00:29.
I do have the correct time setup in the configuration file
latitude: 51.585000
longitude: -9.057000
elevation: 72
unit_system: metric
time_zone: Europe/Dublin
I’m running home assistant OS with a raspberry pi 4, using the SSH add on, the date since ok Date return the correct date Echo $TZ is correct too
