I have just recently set up the Tailscale add-on and everything seems to be working but I wanted to check I understand what is actually going on…
Tailscale provides a peer to peer VPN (i think). In the companion app I have configured the “Home Assistant URL” to be the external IP provided by Tailscale. I have configure the “Internal Connection URL” to be the local IP address of my home assistant instance. I am however unclear on the following:
If my phone is connected to my local network with the home assistant app automatically switch to the local IP address? I assume so as I wouldn’t want it going all the way through the VPN server (not that I think peer to peer would do that anyway…)
If I am away from home and have my Tailscale VPN enabled on my phone, will only the traffic related to home assistant go through this?
Is there any way to see a list of IP addresses that are accessing my home assistant instance? It would be good if I could see any external connections.
Sorry networking is not my strong point! Thanks in advance
