I am not asking for the performance on my iPhone 11 Pro with companion app (latest version), even there it is really bad performance especially when you try to edit the dashboard here.
I am having problems with HA performance in general. My HA runs on an Intel NUC with upgraded SSD to 2TB and Ram updated to 32GB (I know way to much, but I plan in advance, later I want to add several more cameras).
SO I have 2 cameras connected with Frigate that is running as add-on on the same machine with coral USB Stick.
So my CPU usage is on 32% usually with some spike here and there
Memory is just used with 22% in general, not sure why system used swap and now erased it.
So what Is the bad performance you ask maybe. I see it when browsing the dashboard, camera previews are loading slow. Switch to a subview to show 1 camera preview and 2 snapshots takes several seconds to load. Also switch from camera subview to main view take time.
Here you can see a screen recording
I also have problem with camera views stuttering, on Reolik app (Camera producer) it is fluid, on frigate is is stuttering, doorbell (wifi) more then garden (Lan), but not on app.
I can not see why browsing dashboard is that slow, no matter If on my iPhone 11 Pro, iPad Pro (2020), MacBook M1 Max. tried Safari and Chrome with no difference.
There is also no difference if I am at home or accessing over internet, my upload speed at home is 40 Mbit so should be fast enough.
Some ideas or experiences with HA performance and how to make it faster?
