Home Assistant Possible Crash
My Home Assistant host has suffered what appears to be a failure of the web interface on several occasions. Here’s a screen capture from the CLI, is there somewhere I should report this?
Thanks, Mark
It says “out of memory”, so I quess you have a memory issue (HW) to less memory and nothing to do with HA itself
EDIT I’m wrong, it could be a memory leak
increase your swap size :
Hi Canedje,
Thanks for the info. I had already added more memory to the VM, but just to be sure I’ve added some more memory. Will see what happens.
Thanks, Mark
Hi Francis,
Thanks for the info, I will take a look. Must confess I didn’t know you could add more swap if running HA as an appliance, so was happy to see the info you provided.
Thanks, Mark
or there might be a bug in a software (core or custom component / add-on) which causes memory leak.
I do read that more people do have this problem.
They think a memory leak
see:
see my comment above these threat
Seems that could be the cause of my problems… I’ve applied the update, so lets see what happens. Thanks for the info Canedje, much appreciated.
