Home Assistant problem This site can’t be reachedCheck if there is a typo in homeassistant.DNS_PROBE_FINISHED_NXDOMAIN
we face this error every time we try to enter the home assistant.local:8213 [This is the problem we faced ]([picture to the error] We tried multiple solutions like changing the port from 8213 to 4357 and still we had the same error then we tried to use the IP Address in the link and it did not work! and we pinged the home assistant but without avail. We tried to change the network setting (dns… etc) we changed the browser and cleared the history, cookies, and everything and we still have this issue!! we tried to use another laptop with completely different setups and networks and nothing changed
Knowing that we tried all these solutions while we opened the VM
we expect to reach this page because we had entered it before and created an account in the home assistant but after that when we try to reach this page it gives us this error
You state that you run HA in a VM. May you please give more details about your specific configuration ? as it looks to be the source of the problem !
Are you sure the VM has a native IP in your lan and not doing NAT ?
Check the consol on the VM.
It should print the correct IP address there.
I assume this is just a typo? The standard HA port is 8123, not 8213.
After some time in my case i had the same error the url was fine but the issue probably lies in my case at least with the pi4B. It probably takes a minute or 3 to accept the change in the ip adress hence the error DNS_PROBE_FINISHED_NXDOMAIN. After like 5 min it was fixed and i could access the domain again.
I have the same issue. I reinstalled HA on my Rasberry pi 4 and still I get this same error. This happened after the last update. I do not know how to fix this
Had the same problem. It turned out to be the setting of the network on my pc. When in public I was getting a DNS_PROBE_FINISHED_NXDOMAIN response. It has something to do with mdns on windows not supporting .local suffix. If you find the ip of the py and try http://<your_pi_IP>:8123 it should work also or if you login to the http://homeassistant.local:8123 from your phone browser or app. So turn the connection type to private.
I am having a similar issue today, my Home Assistant is a UTM VM on my M1 mac mini which I am converting to solely monitor my automation stuff. Thoughts?
It is a network issue and not a HA issue.
Your connection attempt is never reaching HA, so look on issues on your network and your client device.
Any recommendations? I have tried both shared and bridged.
It should be bridged and you might have to turn on promiscuous mode for the network card to work.
No idea where you do that on a Mac, though.
I moved the Mac mini hosting to hardwire it to the router, and it worked after a couple of other changes and restarts, but it’s working now.
