Sorry for my bad English.
I have a problem with Home Assistant, but can’t find the answer.
My backup db is 2.6GB
Sometimes I can use lightswitches, other times not …
Is there somebody that can give me the answer? This is my log from Home assistant when it’s idle:
22-03-06 10:14:13 INFO (MainThread) [supervisor.store] Loading add-ons from store: 62 all - 0 new - 0 remove
22-03-06 10:29:56 WARNING (MainThread) [supervisor.misc.tasks] Watchdog miss API response from Home Assistant
22-03-06 10:30:11 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant Docker!
22-03-06 10:30:11 INFO (SyncWorker_6) [supervisor.docker.interface] Starting homeassistant
22-03-06 10:30:12 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-03-06 10:30:16 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-06 10:30:16 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-06 10:30:17 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-03-06 10:30:27 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-03-06 10:52:09 ERROR (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant API!
22-03-06 10:52:09 INFO (SyncWorker_4) [supervisor.docker.interface] Restarting ghcr.io/home-assistant/qemux86-64-homeassistant
22-03-06 10:52:12 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-03-06 10:52:17 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-06 10:52:17 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-06 10:52:27 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-03-06 11:00:28 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-03-06 11:07:33 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant Docker!
22-03-06 11:07:33 INFO (SyncWorker_2) [supervisor.docker.interface] Starting homeassistant
22-03-06 11:07:33 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-03-06 11:07:38 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-06 11:07:38 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-06 11:07:49 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-03-06 11:12:34 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-03-06 11:12:57 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-03-06 11:27:05 INFO (MainThread) [supervisor.host.info] Updating local host information
22-03-06 11:27:06 INFO (MainThread) [supervisor.host.services] Updating service information
22-03-06 11:27:06 INFO (MainThread) [supervisor.host.network] Updating local network information
22-03-06 11:27:06 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
22-03-06 11:27:06 INFO (MainThread) [supervisor.host.manager] Host information reload completed
22-03-06 11:30:06 WARNING (MainThread) [supervisor.homeassistant.websocket] Connection is closed
22-03-06 11:30:22 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant Docker!
22-03-06 11:30:22 INFO (SyncWorker_1) [supervisor.docker.interface] Starting homeassistant
22-03-06 11:30:22 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-03-06 11:30:27 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-06 11:30:27 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-06 11:30:32 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-03-06 11:30:38 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-03-06 11:46:44 WARNING (MainThread) [supervisor.misc.tasks] Watchdog miss API response from Home Assistant
22-03-06 11:46:59 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant Docker!
22-03-06 11:46:59 INFO (SyncWorker_7) [supervisor.docker.interface] Starting homeassistant
22-03-06 11:47:00 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-03-06 11:47:05 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-06 11:47:05 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-06 11:47:16 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-03-06 12:00:45 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-03-06 12:09:02 WARNING (MainThread) [supervisor.misc.tasks] Watchdog found a problem with Home Assistant Docker!
22-03-06 12:09:02 INFO (SyncWorker_6) [supervisor.docker.interface] Starting homeassistant
22-03-06 12:09:02 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-03-06 12:09:07 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-06 12:09:07 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-06 12:09:17 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.PLUGIN
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.CORE
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.check] System checks complete
22-03-06 12:12:34 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-03-06 12:12:35 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-03-06 12:12:35 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state CoreState.RUNNING
22-03-06 12:12:35 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
22-03-06 12:13:26 INFO (MainThread) [supervisor.backups.manager] Found 6 backup files
