turma, compartilho meu novo script.
1 - como meu nobreak fica longe do HA (ele fica na impressora 3d), conectei ele em um outro rasp (o mesmo que tem o octopi da 3d) que tem o ser2net fazendo a interface SERIAL-TCP. esse novo nodered foi modificado pra usar uma conexao TCP no lugar da SERIAL.
2 - refinei a parte como o buffer recebido do nobreak eh processado.
se alguem tiver tempo e se animar, poderiamos unificar com o anterior. deixando a opcao de escolher entre usar a serial direto (nobreak conectado no HA) ou remoto via TCP.
"id": "cee84742491cec90",
"type": "tab",
"label": "Ragtech Serial",
"disabled": false,
"info": ""
"id": "e01aec5f975a2fe0",
"type": "debug",
"z": "cee84742491cec90",
"name": "debug Serial IN",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1000,
"y": 620,
"wires": []
"id": "9a8ef3f6c36a13a6",
"type": "inject",
"name": "Request Data",
"props": [],
"repeat": "5",
"crontab": "",
"once": false,
"onceDelay": "1",
"topic": "",
"x": 200,
"y": 80,
"wires": [["64ec956feacc9b87"]]
"id": "f6e354e3b9c0c84c",
"type": "debug",
"name": "debug OUT",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 850,
"y": 180,
"wires": []
"id": "64ec956feacc9b87",
"type": "function",
"name": "Request INFO",
"func": "//PEDE STATS\nmsg.payload = Buffer.from(\"AA0400801E9E\", \"hex\")\nmsg.reset = true;\nreturn msg;\n\n\n//PEDE STATS\n//msg.payload = Buffer.from(\"AA0400F301F4AA0401360138AA0402020206AA0400801E9E\", \"hex\")\n//return msg;\n\n\n//PEDE STATS\n//msg.payload = Buffer.from(\"AA0400F301F4\", \"hex\")\n//return msg;\n\n\n",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 460,
"y": 80,
"wires": [["f6e354e3b9c0c84c", "915f810edd627e3b"]]
"id": "8699bb5eef04e00b",
"type": "function",
"name": "toHexString",
"func": "const toHexString = (bytes) => {\n return Array.from(bytes, (byte) => {\n return ('0' + (byte & 0xff).toString(16)).slice(-2);\n }).join(' ');\n};\n\nvar hexString = toHexString(msg.payload);\nmsg.payload = hexString;\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 790,
"y": 620,
"wires": [["e01aec5f975a2fe0"]]
"id": "5ed339876d5fa2af",
"type": "function",
"name": "Primeiro Comando",
"func": "msg.payload = Buffer.from(\"A004FFE0088B\", \"hex\")\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 470,
"y": 180,
"id": "f768f62acb1e8f29",
"type": "inject",
"props": [],
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "1",
"topic": "",
"x": 190,
"y": 180,
"wires": [["5ed339876d5fa2af"]]
"id": "6ad30b7ec217adb8",
"type": "function",
"name": "Segundo Comando",
"func": "msg.payload = Buffer.from(\"FFFE008E018F\", \"hex\")\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 470,
"y": 260,
"id": "ac2d21ae80912a6a",
"type": "inject",
"props": [],
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": "1",
"topic": "",
"x": 190,
"y": 260,
"wires": [["6ad30b7ec217adb8"]]
"id": "d6880b42400380a4",
"type": "ha-sensor",
"name": "Ragtech Temperature",
"entityConfig": "5f030e19c85b66d7",
"version": 0,
"state": "payload.Temperature",
"stateType": "msg",
"attributes": [],
"inputOverride": "allow",
"outputProperties": [],
"x": 1360,
"y": 260,
"wires": [[]]
"id": "557f343d4699e667",
"name": "Ragtech Battery",
"entityConfig": "da00fe0c0350830d",
"version": 0,
"state": "payload.Battery_State",
"stateType": "msg",
"attributes": [],
"x": 1340,
"y": 320,
"wires": [[]]
"id": "884f8d7eb8c05e9b",
"name": "Ragtech Input Voltage",
"entityConfig": "1289139e401c0dbb",
"version": 0,
"state": "payload.Voltage_In",
"stateType": "msg",
"attributes": [],
"x": 1360,
"y": 380,
"wires": [[]]
"id": "915f810edd627e3b",
"type": "tcp request",
"name": "tcp ragtech",
"server": "192.168.0.147",
"port": "8888",
"out": "count",
"ret": "buffer",
"splitc": "31",
"newline": "",
"trim": false,
"tls": "",
"x": 750,
"y": 300,
"wires": [["8699bb5eef04e00b", "4d971ed73c6fe453"]]
"id": "4d971ed73c6fe453",
"type": "function",
"name": "Processa Dados",
"func": "// ----- Configuração -----\nconst TOTAL_BYTES = 31; // Número esperado de bytes na resposta\nconst HEADER_BYTE = 0xAA; // Primeiro byte esperado\nconst HEADER_BYTE_2 = 0x09; // Primeiro byte esperado\n\n// ----- Buffer para armazenar os dados até completar 31 bytes -----\nvar buffer = flow.get(\"tcpBuffer\") || Buffer.alloc(0);\n\n// ----- Acumular bytes recebidos -----\nbuffer = Buffer.concat([buffer, msg.payload]);\n\n// Se ainda não temos os 31 bytes, armazenamos e aguardamos mais dados\nif (buffer.length < TOTAL_BYTES) {\n flow.set(\"tcpBuffer\", buffer);\n return null;\n}\n\n// Se temos mais do que 31 bytes, pegamos os 31 primeiros e descartamos o restante\nconst data = buffer.slice(0, TOTAL_BYTES);\nflow.set(\"tcpBuffer\", Buffer.alloc(0)); // Reset do buffer\n\n// ----- Validação do primeiro byte -----\nif (data[0] !== HEADER_BYTE || data[1] != HEADER_BYTE_2) {\n node.warn(\"Resposta inválida: primeiro byte não é 0xAA\");\n return null; // Descarta o pacote inválido\n}\n\n// ----- Extração dos dados -----\nlet iOut = parseFloat((data[13] * 0.1152).toFixed(2)); // Corrente de saída (A)\nlet vOut = parseFloat((data[30] * 0.555).toFixed(1)); // Tensão de saída (V)\nlet wOut = parseFloat((iOut * vOut).toFixed(1)); // Potência de saída (W)\n\nlet vIn = parseFloat((data[12] * 1.06).toFixed(1)); // Tensão de entrada (V)\nlet wIn = parseFloat((iOut * vIn).toFixed(1)); // Potência de entrada (W)\n\nlet batteryInUse = vIn < 20 || wIn < 5; // Se Voltage_In < 5V ou Power_In < 5W, a bateria está sendo usada\n\nlet status = {\n \"Power_Out_Percent\": data[14], // Posição 0x0E\n \"Current_Out\": iOut, // Corrente de saída (A)\n \"Voltage_Out\": vOut, // Tensão de saída (V)\n \"Voltage_In\": vIn, // Tensão de entrada (V)\n \"Power_Out\": wOut, // Potência de saída (W)\n \"Power_In\": wIn, // Potência de entrada (W)\n \"Temperature\": data[15], // Posição 0x0F\n \"Battery_State\": Math.round(data[8] * 0.392), // Posição 0x08\n \"Battery_Voltage\": parseFloat((data[11] * 0.0671).toFixed(2)), // Posição 0x0B\n \"Frequency\": parseFloat((data[24] * -0.1152 + 65).toFixed(2)), // Posição 0x18\n \"Battery_In_Use\": batteryInUse // \"ON\" se estiver em uso, \"OFF\" se estiver na energia da rede\n};\n\n// ----- Enviar resposta formatada -----\nmsg.payload = status;\nreturn msg;",
"outputs": 1,
"timeout": 0,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1000,
"y": 300,
"wires": [
"502581569e316c3d",
"d6880b42400380a4",
"884f8d7eb8c05e9b",
"557f343d4699e667",
"fc306eafa6a2bced",
"a8debcd858ca0761",
"292c6a834da90ce6",
"4249875880206a83",
"839eae68fdb6e066"
"id": "502581569e316c3d",
"type": "debug",
"name": "debug 1",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"x": 1180,
"y": 120,
"wires": []
"id": "fc306eafa6a2bced",
"name": "Ragtech Power Output Percent",
"entityConfig": "24ba83de7f3c5cad",
"version": 0,
"state": "payload.Power_Out_Percent",
"stateType": "msg",
"attributes": [],
"x": 1390,
"y": 460,
"wires": [[]]
"id": "a8debcd858ca0761",
"name": "Ragtech Current Out",
"entityConfig": "aa29efe6fa186870",
"version": 0,
"state": "payload.Current_Out",
"stateType": "msg",
"attributes": [],
"x": 1360,
"y": 540,
"wires": [[]]
"id": "292c6a834da90ce6",
"type": "ha-binary-sensor",
"name": "Ragtech Battery In Use",
"entityConfig": "53211f1120a99c42",
"version": 0,
"state": "payload.Battery_In_Use",
"stateType": "msg",
"attributes": [],
"x": 1370,
"y": 620,
"wires": [[]]
"id": "4249875880206a83",
"name": "Ragtech Power Output",
"entityConfig": "048810605b0c2c26",
"version": 0,
"state": "payload.Power_Out",
"stateType": "msg",
"attributes": [],
"x": 1360,
"y": 700,
"wires": [[]]
"id": "839eae68fdb6e066",
"name": "Ragtech Battery Voltage",
"entityConfig": "026beef6bd22c407",
"version": 0,
"state": "payload.Battery_Voltage",
"stateType": "msg",
"attributes": [],
"x": 1370,
"y": 780,
"wires": [[]]
"id": "5f030e19c85b66d7",
"type": "ha-entity-config",
"server": "9074df74.a057",
"deviceConfig": "e2047f52686b2525",
"version": "6",
"entityType": "sensor",
"haConfig": [
{ "property": "name", "value": "Ragtech Temperature" },
{ "property": "icon", "value": "" },
{ "property": "entity_picture", "value": "" },
{ "property": "entity_category", "value": "" },
{ "property": "device_class", "value": "temperature" },
{ "property": "unit_of_measurement", "value": "°C" },
{ "property": "state_class", "value": "" }
"resend": false,
"debugEnabled": false
"id": "da00fe0c0350830d",
"version": "6",
"haConfig": [
{ "property": "name", "value": "Ragtech Battery" },
{ "property": "device_class", "value": "battery" },
{ "property": "unit_of_measurement", "value": "%" },
"resend": false,
"id": "1289139e401c0dbb",
"version": "6",
"haConfig": [
{ "property": "name", "value": "Ragtech Input Voltage" },
{ "property": "device_class", "value": "voltage" },
{ "property": "unit_of_measurement", "value": "V" },
"resend": false,
"id": "24ba83de7f3c5cad",
"version": 6,
"haConfig": [
{ "property": "name", "value": "Ragtech Power Output Percent" },
{ "property": "device_class", "value": "power_factor" },
{ "property": "state_class", "value": "measurement" }
"resend": false,
"id": "aa29efe6fa186870",
"version": 6,
"haConfig": [
{ "property": "name", "value": "Ragtech Current Out" },
{ "property": "device_class", "value": "current" },
{ "property": "unit_of_measurement", "value": "A" },
"resend": false,
"id": "53211f1120a99c42",
"version": 6,
"entityType": "binary_sensor",
"haConfig": [
{ "property": "name", "value": "Ragtech Battery In Use" },
{ "property": "device_class", "value": "" }
"resend": false,
"id": "048810605b0c2c26",
"version": 6,
"haConfig": [
{ "property": "name", "value": "Ragtech Power Output" },
{ "property": "device_class", "value": "power" },
{ "property": "unit_of_measurement", "value": "W" },
"resend": false,
"id": "026beef6bd22c407",
"version": 6,
"haConfig": [
{ "property": "name", "value": "Ragtech Battery Voltage" },
"resend": false,
"id": "9074df74.a057",
"type": "server",
"name": "Home Assistant",
"addon": true
"id": "e2047f52686b2525",
"type": "ha-device-config",
"name": "Nobreak Ragtech Escritorio",
"hwVersion": "4162",
"manufacturer": "Ragtech",
"model": "NEP 1200VA",
"swVersion": ""
