I recently had the RPI 2 and noticed that sometimes my instance was not available anymore (once in a few days), i also noticed i could not SSH to the host anymore. I was running HA on docker on the rPI.
I started a topic with some people and they suggested me to upgrade the RPI to rpi 4 with 4gb of ram. Also to get an SSD along with it so i could rule out the possibility of the microsd failing.
now I bought the rpi4 and a 500gb ssd, set up HA OS on it (so not using linux + docker anymore but directly installed Hassio). And I noticed the same issue. I plugged in my ssd into my pc because I could see that when I replugged my RPI then the logs would be gone but nothing special was in the logs.
here are the last lines of today:
2021-07-05 03:44:24 WARNING (Thread-9) [pychromecast.socket_client] [Living Room speaker(192.168.0.230):8009] Heartbeat timeout, resetting connection
2021-07-05 03:44:40 ERROR (Thread-9) [pychromecast.socket_client] [Living Room speaker(192.168.0.230):8009] Failed to connect to service ServiceInfo(type='host', data=('192.168.0.230', 8009)), retrying in 5.0s
2021-07-05 11:49:10 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.desktop_1bb00jk_msi_z170a_tomahawk_ms_7970_nuvoton_nct6793d_voltages_cpu_vcore is taking over 10 seconds
2021-07-05 13:57:16 WARNING (zeroconf-Engine-242) [zeroconf] Choked at offset 13670 while unpacking b'\x13\x10\x80\x00\x00\x00\x00\x02\x00\x00\x00\x00\x06WP3543\x08_display\x04_tcp\x05local\x00\x00\xff\x00\x01\x06WP3543\x08_display\x04_tcp\x05local\x00\x00!\x00\x01\x00\x00\x00x\x00\x14\x00\x00\x00\x00\x1cR\x06WP3543\x05local\x00\xc0,\x00\x10\x00\x01\x00\x00\x11\x94\x0043container_id={DE05F4D3-8FD9-4170-8A30-CC1E6DE332B1}'
File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 754, in __init__
self.read_others()
File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 825, in read_others
domain = self.read_name()
File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 886, in read_name
length = self.data[off]
IndexError: index out of range
2021-07-05 16:11:41 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.desktop_1bb00jk_msi_z170a_tomahawk_ms_7970_nuvoton_nct6793d_voltages_cpu_vcore is taking over 10 seconds
2021-07-05 16:36:02 ERROR (MainThread) [custom_components.hacs] <Plugin custom-cards/viewport-accessibility> GitHub returned 404 for https://api.github.com/repos/custom-cards/viewport-accessibility
2021-07-05 16:36:02 ERROR (MainThread) [custom_components.hacs] custom-cards/viewport-accessibility - GitHub returned 404 for https://api.github.com/repos/custom-cards/viewport-accessibility
2021-07-05 18:22:41 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.desktop_1bb00jk_msi_z170a_tomahawk_ms_7970_nuvoton_nct6793d_voltages_cpu_vcore is taking over 10 seconds
2021-07-05 18:23:01 WARNING (MainThread) [homeassistant.components.sensor] Updating openhardwaremonitor sensor took longer than the scheduled update interval 0:00:30
2021-07-05 18:23:41 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.desktop_1bb00jk_msi_z170a_tomahawk_ms_7970_nuvoton_nct6793d_voltages_cpu_vcore is taking over 10 seconds
Can I also somewhere on the physical ssd see the system logs? I checked all the docker containers on the SSD but I could not find any logs on there:
These are the addons I have:
These custom components:
I am not doing crazy things with my HA. I have 4 switches linked and 1 light. I run a few automations to auto turn on and off 2 of the switches each day.
I also have some phone trackers for me and my girlfriend. Aswell some data from my PC’s hardware is flowing in to HA.
Any idea what I could do? Might this be an IP Issue?
I had a static IP configured in the rpi2 (using raspi-config), however now I have HA directly installed so raspi config is not possible. I could maybe use DHCP settings of my modem to assign a static ip? But I don’t think this is the issue since the rpi2 had a static ip and had the issue already.
