ensoe
(Robin Jansson)
November 29, 2018, 7:01pm
1
I am new to Home Assistant and have bought myself a kit containing a Raspberry Pi 3B+ and a RaspBee Onboard card. I am having trouble getting Hass.io to recognize the onboard card.
Here are the steps I have taken:
Install Hass.io
Added to config.txt:
enable_uart=1
dtoverlay=pi3-miniuart-bt
BLANK SPACE (As suggested by Marthoc)
Mount RaspBee (While RPi was turned off)
Tried to add deCONZ integration, failing with error message “No deCONZ bridges discovered”
Am I missing a vital step here or is my RaspBee DOA?
Robban
November 29, 2018, 8:06pm
2
Have you installed the deconz gateway add-on?
ensoe
(Robin Jansson)
November 29, 2018, 8:10pm
3
No, I have not. Is there a guide for this? I tried installing using dresden electronics own guide, but failed at the point where a command I was supposed to use did not exist in the Hass.io installation.
ensoe
(Robin Jansson)
November 29, 2018, 8:16pm
5
I tried following that guide, added the github link to the addon page. But I get prompted with a red text saying “The addon is not available on your system”. Sorry if I am missing something obvious here, brand new to hass.io
Robban
November 29, 2018, 8:17pm
6
Ok, then it might be a 3B+ issue. Create an issue with marathon and see what he says. Im neither using 3B+ or hassio.
ensoe
(Robin Jansson)
November 29, 2018, 8:32pm
7
Thanks for the tip, I will do that.
marthocoo
(Mark Coombes)
November 30, 2018, 2:47am
8
So you’ve gone to Hass.io - Add-On Store, and added my repo. Then scrolled to the bottom, found my repo, clicked on deCONZ, and then clicked Install? There no reason why it shouldn’t be available on your system.
ensoe
(Robin Jansson)
November 30, 2018, 5:34am
9
I removed the repository and tried to re-add it. Then I was met with this error message in the log and no card shows up:
Log:
18-11-30 05:29:19 INFO (MainThread) [hassio.addons.git] Clone add-on hassio-addons/deconz at master · marthoc/hassio-addons · GitHub repository
18-11-30 05:29:20 ERROR (MainThread) [hassio.addons.git] Can’t clone hassio-addons/deconz at master · marthoc/hassio-addons · GitHub repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v hassio-addons/deconz at master · marthoc/hassio-addons · GitHub /data/addons/git/1087a9cd
stderr: 'Cloning into ‘/data/addons/git/1087a9cd’…
fatal: repository ‘hassio-addons/deconz at master · marthoc/hassio-addons · GitHub ’ not found
18-11-30 05:29:20 ERROR (MainThread) [hassio.addons] Can’t load from repository hassio-addons/deconz at master · marthoc/hassio-addons · GitHub
18-11-30 05:29:20 INFO (MainThread) [hassio.addons] Load add-ons: 19 all - 0 new - 0 remove
I might do a full re-installation if there is not an easy fix.
ensoe
(Robin Jansson)
November 30, 2018, 9:37pm
10
I have now done a complete reinstall and the problem persists. Please advice.
18-11-30 21:35:58 INFO (MainThread) [hassio.addons.git] Clone add-on https://github.com/marthoc/hassio-addons/tree/master/deconz repository
18-11-30 21:35:59 ERROR (MainThread) [hassio.addons.git] Can’t clone https://github.com/marthoc/hassio-addons/tree/master/deconz repository: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/marthoc/hassio-addons/tree/master/deconz /data/addons/git/1087a9cd
fatal: repository ‘https://github.com/marthoc/hassio-addons/tree/master/deconz/ ’ not found
18-11-30 21:35:59 ERROR (MainThread) [hassio.addons] Can’t load from repository https://github.com/marthoc/hassio-addons/tree/master/deconz
18-11-30 21:35:59 INFO (MainThread) [hassio.addons] Load add-ons: 47 all - 0 new - 0 remove
ensoe
(Robin Jansson)
November 30, 2018, 10:52pm
11
Solved by adding the root repository of Marthoc instead of the addon specific link. Goes to show how the small things matter when you don’t are doing something new
puk1966
February 9, 2019, 7:10pm
12
Hi ensoe,
Looks like I have the same configuration as you (RPI3b+ and Rasbpee).
What do you mean with “the root repository of Marthoc” ?
What exactly did you do to solve your issue ?
Thanks in advance.
marthocoo
(Mark Coombes)
February 9, 2019, 7:27pm
13
puk1966
February 9, 2019, 7:43pm
14
Aaaaah I see, yes I did that but still problems
Will continue my investigation/findings in : https://github.com/marthoc/hassio-addons/issues/78
boelle
(Bo Herrmannsen)
January 4, 2021, 2:09pm
16
i just installed the module and added the deconz add on
are there more to it than this?
boelle
(Bo Herrmannsen)
January 4, 2021, 2:36pm
18
added to config.txt:
enable_uart=1
what next?
