Home Assistant reboots with Echo Atom
Hi
My Home Assistant is on a PI 3 with HassOS - versions:
  • Core = 2024.7.1
  • Supervisor = 2024.06.2
  • Operating System = 12.4
  • Frontend = 20240705.0
I have an Echo Atom with a local Voice Assistant pipeline. The Atom shows white, turns blue with wake word and then flashes blue. Then keeps flashing blue and then the Home Assistant reboots :frowning:
What should I try? What logs (and where) to look for clues?
Best wishes
David
The cookbook. Troubleshooting section. Crashing pi.
That said. You’re gon a be borderline from a.memory perspective best case with current builds on a pi3. If you’re doing piper/whisper on that same pi my bet is it’s screaming from a memory perspective. But we’re only guessing without a log. And that link tells you how to get It.
