Home assistant refused to connect after upgrade
I am running HA on proxmox (IP 192.168.1.120)
HA server has IP 192.168.1.123.
I was able to connect to HA from my laptop using URL ‘homeassistant.local’. I saw an update available message on HA server. I did it. After that I got refused to connect using homeassistant.local or 192.168.1.123. The same result using 192.168.1.123:80 or 192.168.1.123:8123. I can get to Home Assistant observer (192.168.1.123:4357). Any suggestion?
Probeable your session was invalidated. Try to clear the browser cache or switch to another device or browser for testing.
Sounds like the host is up if you got a response from the Observer.
Did you go into the console on the HAOS VM in Proxmox? At the ha> prompt you can type “login” and then “docker ps” to see if core is running.
Or run “ha core logs -f” and see if there’s anything in the startup logs.
