2021-04-24 07:51:00 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
response.begin()
File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.8/http/client.py", line 268, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.8/socket.py", line 669, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.8/ssl.py", line 1241, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.8/ssl.py", line 1099, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 531, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 735, in reraise
raise value
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 447, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='auth.tado.com', port=443): Read timed out. (read timeout=10)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/tado/__init__.py", line 83, in <lambda>
lambda now: tadoconnector.update(),
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 285, in wrapper
result = method(*args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/tado/__init__.py", line 173, in update
self.update_sensor("device", device["shortSerialNo"])
File "/usr/src/homeassistant/homeassistant/components/tado/__init__.py", line 182, in update_sensor
data = self.tado.getDeviceInfo(sensor)
File "/usr/local/lib/python3.8/site-packages/PyTado/interface.py", line 411, in getDeviceInfo
data = self._apiCall(cmd=cmd, domain=self.DEVICE_DOMAIN, device_id=device_id)
File "/usr/local/lib/python3.8/site-packages/PyTado/interface.py", line 62, in _apiCall
self._refresh_token()
File "/usr/local/lib/python3.8/site-packages/PyTado/interface.py", line 126, in _refresh_token
response = self._http_session.request("post", url, params=data, timeout=self.timeout, data=json.dumps({}).encode('utf8'),
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 542, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 655, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='auth.tado.com', port=443): Read timed out. (read timeout=10)
2021-04-24 07:51:35 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from DESKTOP-MBV6FO4.broadband (192.168.0.173). (Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/90.0.4430.85 Safari/537.36)
2021-04-24 07:52:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.ping_eolo is taking over 10 seconds
2021-04-24 07:53:34 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.ping_eolo is taking over 10 seconds
2021-04-24 07:55:04 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.ping_eolo is taking over 10 seconds
2021-04-24 07:55:08 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 249bd779813af252180370beb4222937082f516babe03b9e2dee350250be5ff6 from 192.168.0.185
2021-04-24 07:55:09 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook 249bd779813af252180370beb4222937082f516babe03b9e2dee350250be5ff6 from 192.168.0.185
