HOST:
âââ
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 5.4.79-v7 ([email protected]) (gcc version 9.3.0 (Buildroot -g45d6d28)) #1 SMP Fri Dec 18 20:43:53 UTC 2020
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Plus Rev 1.3
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] Reserved memory: created CMA memory pool at 0x37400000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] On node 0 totalpages: 242688
[ 0.000000] Normal zone: 2133 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 242688 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 20 pages/cpu s49868 r8192 d23860 u81920
[ 0.000000] pcpu-alloc: s49868 r8192 d23860 u81920 alloc=20*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 240555
[ 0.000000] Kernel command line: zram.enabled=1 zram.num_devices=3 apparmor=1 security=apparmor rootwait systemd.machine_id=9eb893a12c2549b39444fbcbfc122a32 cgroup_enable=memory fsck.repair=yes coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=a3ec664e-32ce-4665-95ea-7ae90ce9aa20 rootfstype=squashfs ro rauc.slot=B
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 879400K/970752K available (10240K kernel code, 731K rwdata, 2896K rodata, 1024K init, 844K bss, 25816K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 32546 entries in 64 pages
[ 0.000000] rcu: Hierarchical RCU implementation.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 10 jiffies.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] random: get_random_bytes called from start_kernel+0x328/0x50c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000020] Switching to timer-based delay loop, resolution 52ns
[ 0.000278] Console: colour dummy device 80x30
[ 0.000897] printk: console [tty1] enabled
[ 0.000963] Calibrating delay loop (skipped), value calculated using timer frequency⊠38.40 BogoMIPS (lpj=192000)
[ 0.001012] pid_max: default: 32768 minimum: 301
[ 0.001222] LSM: Security Framework initializing
[ 0.001363] AppArmor: AppArmor initialized
[ 0.001589] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.001636] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes, linear)
[ 0.002933] CPU: Testing write buffer coherency: ok
[ 0.003531] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.004524] Setting up static identity map for 0x100000 - 0x10003c
[ 0.004763] rcu: Hierarchical SRCU implementation.
[ 0.005486] smp: Bringing up secondary CPUs âŠ
[ 0.006657] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.007957] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.009153] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.009311] smp: Brought up 1 node, 4 CPUs
[ 0.009402] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.009430] CPU: All CPU(s) started in HYP mode.
[ 0.009455] CPU: Virtualization extensions available.
[ 0.010574] devtmpfs: initialized
[ 0.027533] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.027852] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.027909] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.031208] pinctrl core: initialized pinctrl subsystem
[ 0.032331] NET: Registered protocol family 16
[ 0.036923] DMA: preallocated 1024 KiB pool for atomic coherent allocations
[ 0.041730] audit: initializing netlink subsys (disabled)
[ 0.042041] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.043741] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.043780] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.044024] Serial: AMBA PL011 UART driver
[ 0.046015] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.070097] raspberrypi-firmware soc:firmware: Attached to firmware from 2020-10-22 14:06, variant start
[ 0.080110] raspberrypi-firmware soc:firmware: Firmware hash is 74e754ff8947c58d2773253f77f6f68a303188f8
[ 0.134037] bcm2835-dma 3f007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.136179] SCSI subsystem initialized
[ 0.136454] usbcore: registered new interface driver usbfs
[ 0.136536] usbcore: registered new interface driver hub
[ 0.136691] usbcore: registered new device driver usb
[ 0.136784] mc: Linux media interface: v0.10
[ 0.136847] videodev: Linux video capture interface: v2.00
[ 0.139070] clocksource: Switched to clocksource arch_sys_counter
[ 1.320622] VFS: Disk quotas dquot_6.6.0
[ 1.320776] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 1.320998] FS-Cache: Loaded
[ 1.321289] CacheFiles: Loaded
[ 1.322001] AppArmor: AppArmor Filesystem Enabled
[ 1.333216] thermal_sys: Registered thermal governor âstep_wiseâ
[ 1.333606] NET: Registered protocol family 2
[ 1.334520] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 1.334594] TCP established hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 1.334736] TCP bind hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 1.334947] TCP: Hash tables configured (established 8192 bind 8192)
[ 1.335155] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.335230] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 1.335550] NET: Registered protocol family 1
[ 1.336346] RPC: Registered named UNIX socket transport module.
[ 1.336378] RPC: Registered udp transport module.
[ 1.336405] RPC: Registered tcp transport module.
[ 1.336432] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.338471] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 1.341948] Initialise system trusted keyrings
[ 1.342226] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[ 1.354021] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.354402] FS-Cache: Netfs ânfsâ registered for caching
[ 1.355107] NFS: Registering the id_resolver key type
[ 1.355164] Key type id_resolver registered
[ 1.355191] Key type id_legacy registered
[ 1.355228] nfs4filelayout_init: NFSv4 File Layout Driver RegisteringâŠ
[ 1.356679] Key type asymmetric registered
[ 1.356710] Asymmetric key parser âx509â registered
[ 1.356778] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 1.357063] io scheduler mq-deadline registered
[ 1.357093] io scheduler kyber registered
[ 1.360570] bcm2708_fb soc:fb: FB found 1 display(s)
[ 1.374382] Console: switching to colour frame buffer device 82x26
[ 1.382314] bcm2708_fb soc:fb: Registered framebuffer for display 0, size 656x416
[ 1.393374] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.396853] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.403598] vc-sm: Videocore shared memory driver
[ 1.407257] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 1.426802] brd: module loaded
[ 1.442756] loop: module loaded
[ 1.446597] zram: Added device: zram0
[ 1.450378] zram: Added device: zram1
[ 1.453988] zram: Added device: zram2
[ 1.458114] Loading iSCSI transport class v2.0-870.
[ 1.462738] libphy: Fixed MDIO Bus: probed
[ 1.465640] tun: Universal TUN/TAP device driver, 1.6
[ 1.468800] usbcore: registered new interface driver lan78xx
[ 1.471774] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.675274] Core Release: 2.80a
[ 1.678135] Setting default values for core params
[ 1.681025] Finished setting default values for core params
[ 1.884197] Using Buffer DMA mode
[ 1.886964] Periodic Transfer Interrupt Enhancement - disabled
[ 1.889870] Multiprocessor Interrupt Enhancement - disabled
[ 1.892768] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.895627] Dedicated Tx FIFOs mode
[ 1.899016] WARN::dwc_otg_hcd_init:1072: FIQ DMA bounce buffers: virt = b7514000 dma = 0xf7514000 len=9024
[ 1.904691] FIQ FSM acceleration enabled for :
[ 1.904691] Non-periodic Split Transactions
[ 1.904691] Periodic Split Transactions
[ 1.904691] High-Speed Isochronous Endpoints
[ 1.904691] Interrupt/Control Split Transaction hack enabled
[ 1.917818] dwc_otg: Microframe scheduler enabled
[ 1.917895] WARN::hcd_init_fiq:457: FIQ on core 1
[ 1.920456] WARN::hcd_init_fiq:458: FIQ ASM at 80748ad4 length 36
[ 1.923061] WARN::hcd_init_fiq:496: MPHI regs_base at bb810000
[ 1.925686] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.928412] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.931327] dwc_otg 3f980000.usb: irq 56, io mem 0x00000000
[ 1.934182] Init: Port Power? op_state=1
[ 1.936963] Init: Power Port (0)
[ 1.940057] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[ 1.945670] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.948644] usb usb1: Product: DWC OTG Controller
[ 1.951615] usb usb1: Manufacturer: Linux 5.4.79-v7 dwc_otg_hcd
[ 1.954585] usb usb1: SerialNumber: 3f980000.usb
[ 1.958217] hub 1-0:1.0: USB hub found
[ 1.961169] hub 1-0:1.0: 1 port detected
[ 1.964771] dwc_otg: FIQ enabled
[ 1.964781] dwc_otg: NAK holdoff enabled
[ 1.964791] dwc_otg: FIQ split-transaction FSM enabled
[ 1.964806] Module dwc_common_port init
[ 1.965156] usbcore: registered new interface driver usb-storage
[ 1.968132] usbcore: registered new interface driver usbserial_generic
[ 1.971026] usbserial: USB Serial support registered for generic
[ 1.974039] mousedev: PS/2 mouse device common for all mice
[ 1.977941] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.983780] sdhci: Secure Digital Host Controller Interface driver
[ 1.986624] sdhci: Copyright© Pierre Ossman
[ 1.990062] mmc-bcm2835 3f300000.mmcnr: could not get clk, deferring probe
[ 1.992548] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
[ 1.993942] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.996443] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.997925] hidraw: raw HID events driver © Jiri Kosina
[ 1.999369] usbcore: registered new interface driver usbhid
[ 2.000692] usbhid: USB HID core driver
[ 2.002490] vchiq: vchiq_init_state: slot_zero = (ptrval)
[ 2.004904] [vc_sm_connected_init]: start
[ 2.012029] [vc_sm_connected_init]: end - returning 0
[ 2.014833] IPVS: Registered protocols (TCP, UDP, SCTP, AH, ESP)
[ 2.016392] IPVS: Connection hash table configured (size=4096, memory=32Kbytes)
[ 2.018321] IPVS: ipvs loaded.
[ 2.019820] IPVS: [rr] scheduler registered.
[ 2.022126] NET: Registered protocol family 10
[ 2.024403] Segment Routing with IPv6
[ 2.025910] NET: Registered protocol family 17
[ 2.027399] Bridge firewalling registered
[ 2.028917] Key type dns_resolver registered
[ 2.030876] Registering SWP/SWPB emulation handler
[ 2.032582] registered taskstats version 1
[ 2.034070] Loading compiled-in X.509 certificates
[ 2.035896] Key type ._fscrypt registered
[ 2.037432] Key type .fscrypt registered
[ 2.038980] AppArmor: AppArmor sha1 policy hashing enabled
[ 2.046839] uart-pl011 3f201000.serial: cts_event_workaround enabled
[ 2.048445] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 81, base_baud = 0) is a PL011 rev2
[ 2.052669] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 2.055125] mmc-bcm2835 3f300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 2.056706] mmc-bcm2835 3f300000.mmcnr: DMA channel allocated
[ 2.082485] sdhost: log_buf @ (ptrval) (f7513000)
[ 2.120834] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 2.124901] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.128872] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 2.134124] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 2.137369] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.142052] printk: console [netcon0] enabled
[ 2.144204] netconsole: network logging started
[ 2.146433] of_cfs_init
[ 2.148709] of_cfs_init: OK
[ 2.151689] Waiting for root device PARTUUID=a3ec664e-32ce-4665-95ea-7ae90ce9aa20âŠ
[ 2.179153] Indeed it is in host mode hprt0 = 00021501
[ 2.194418] random: fast init done
[ 2.200237] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.208174] mmc0: new high speed SDXC card at address 5048
[ 2.209978] mmcblk0: mmc0:5048 SDCHE 58.0 GiB
[ 2.228919] mmc1: new high speed SDIO card at address 0001
[ 2.248350] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[ 2.282069] VFS: Mounted root (squashfs filesystem) readonly on device 179:5.
[ 2.286587] devtmpfs: mounted
[ 2.295637] Freeing unused kernel memory: 1024K
[ 2.319387] Run /sbin/init as init process
[ 2.389127] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.391206] Indeed it is in host mode hprt0 = 00001101
[ 2.629373] usb 1-1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 2.632934] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.636389] hub 1-1:1.0: USB hub found
[ 2.639263] hub 1-1:1.0: 4 ports detected
[ 2.742797] systemd[1]: System time before build time, advancing clock.
[ 2.772718] systemd[1]: systemd 246 running in system mode. (+PAM -AUDIT -SELINUX -IMA +APPARMOR -SMACK -SYSVINIT -UTMP -LIBCRYPTSETUP +GCRYPT +GNUTLS -ACL -XZ -LZ4 -ZSTD -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[ 2.780857] systemd[1]: Detected architecture arm.
[ 2.855291] systemd[1]: Set hostname to .
[ 2.857552] systemd[1]: Installed transient /etc/machine-id file.
[ 2.959167] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 3.089316] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[ 3.092206] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 3.094078] hub 1-1.1:1.0: USB hub found
[ 3.099316] hub 1-1.1:1.0: 3 ports detected
[ 3.119875] systemd[1]: /usr/lib/systemd/system/docker.socket:6: ListenStream= references a path below legacy directory /var/run/, updating /var/run/docker.sock â /run/docker.sock; please update the unit file accordingly.
[ 3.290327] systemd[1]: Queued start job for default target Multi-User System.
[ 3.293062] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.298438] systemd[1]: Created slice system-getty.slice.
[ 3.302212] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.305203] systemd[1]: Created slice system-modprobe.slice.
[ 3.308675] random: systemd: uninitialized urandom read (16 bytes read)
[ 3.311887] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 3.317010] systemd[1]: Created slice User and Session Slice.
[ 3.320746] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.326062] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.331934] systemd[1]: Reached target HassOS zram targets.
[ 3.335667] systemd[1]: Reached target Paths.
[ 3.339300] systemd[1]: Reached target Remote File Systems.
[ 3.342910] systemd[1]: Reached target Slices.
[ 3.351251] systemd[1]: Listening on Process Core Dump Socket.
[ 3.355397] systemd[1]: Listening on Journal Audit Socket.
[ 3.359301] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.363179] systemd[1]: Listening on Journal Socket.
[ 3.367109] systemd[1]: Listening on udev Control Socket.
[ 3.370922] systemd[1]: Listening on udev Kernel Socket.
[ 3.374705] systemd[1]: Condition check resulted in Huge Pages File System being skipped.
[ 3.381863] systemd[1]: Mounting POSIX Message Queue File SystemâŠ
[ 3.390035] systemd[1]: Mounting Kernel Debug File SystemâŠ
[ 3.398760] systemd[1]: Mounting Kernel Trace File SystemâŠ
[ 3.407985] systemd[1]: Starting Create list of static device nodes for the current kernelâŠ
[ 3.417450] systemd[1]: Starting Load Kernel Module drmâŠ
[ 3.430228] systemd[1]: Starting Journal ServiceâŠ
[ 3.438476] systemd[1]: Starting Remount Root and Kernel File SystemsâŠ
[ 3.447864] systemd[1]: Starting Coldplug All udev DevicesâŠ
[ 3.453767] dwc_otg_handle_wakeup_detected_intr lxstate = 2
[ 3.459218] systemd[1]: Starting HassOS ZRAM swapâŠ
[ 3.468074] systemd[1]: Starting HassOS ZRAM tmpâŠ
[ 3.476438] systemd[1]: Starting HassOS ZRAM varâŠ
[ 3.487331] systemd[1]: Mounted POSIX Message Queue File System.
[ 3.491880] systemd[1]: Mounted Kernel Debug File System.
[ 3.496445] systemd[1]: Mounted Kernel Trace File System.
[ 3.503713] systemd[1]: Finished Create list of static device nodes for the current kernel.
[ 3.509711] systemd[1]: Started Journal Service.
[ 3.558443] zram2: detected capacity change from 0 to 16777216
[ 3.558518] zram0: detected capacity change from 0 to 242167808
[ 3.563002] zram1: detected capacity change from 0 to 33554432
[ 3.829157] usb 1-1.1.1: new high-speed USB device number 4 using dwc_otg
[ 3.851208] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
âââ
