Hass.io running on a Asus Tinker Board v1.2. (power source 2,5A).
Hass.io will restart frequently with nothing to show in the error logs. Can work just fine for hours, and then just restart the whole OS.
See latest entries from my log file:
2019-02-28 18:04:29 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=82 from 2019-02-28 16:53:24.923618)
2019-02-28 18:04:31 ERROR (MainThread) [homeassistant.setup] Setup failed for input_boolean: Component failed to initialize.
2019-02-28 18:04:36 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback <function EventBus.async_listen_once..onetime_listener at 0xb2ae0c48>
File “uvloop/cbhandles.pyx”, line 64, in uvloop.loop.Handle._run
File “/usr/local/lib/python3.7/site-packages/homeassistant/core.py”, line 626, in onetime_listener
self._hass.async_run_job(listener, event)
File “/usr/local/lib/python3.7/site-packages/homeassistant/core.py”, line 333, in async_run_job
target(*args)
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/person/init.py”, line 342, in person_start_hass
self.person_updated()
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/person/init.py”, line 363, in person_updated
self._update_state()
File “/usr/local/lib/python3.7/site-packages/homeassistant/components/person/init.py”, line 374, in _update_state
for entity_id in self._config.get(CONF_DEVICE_TRACKERS, []):
TypeError: ‘NoneType’ object is not iterable
Is there any way of SSH into the machine? You could then take a look at the docker log. It should tell you at least something about the restarting of the homeassistant container.
I have connected via SSH, but I am unable to locate the docker log file. I do not have the following folders (Google) :
/usr/share/hassio/homeassistant/homeassistant.log
/var/lib/docker/containers/*/*json.log
