Every time I try to create or customize an automation, HomeAssistant restarts. The error occurs regardless of the browser or automation I open. What log would be useful to attach here to analyze? I am thankful for your help in advance
After you restart post the contents of config/home-assistant.log.1
This is the log from before the restart.
The log from after the restart may also be useful, it is config/home-assistant.log
here is todays logs
2024-04-18 00:00:06.318 ERROR (MainThread) [homeassistant.util.logging] Exception in async_timer_finished when dispatching 'scheduler_timer_finished': ('3452f5',)
File "/config/custom_components/scheduler/switch.py", line 275, in async_timer_finished
await self._action_handler.async_queue_actions(
File "/config/custom_components/scheduler/actions.py", line 260, in async_queue_actions
for queue in self._queues.values():
RuntimeError: dictionary changed size during iteration
2024-04-18 01:01:26.577 WARNING (MainThread) [aioesphomeapi.connection] co2schlafzimmer @ 192.168.178.221: Connection error occurred: Ping response not received after 90.0 seconds
2024-04-18 01:01:29.685 WARNING (MainThread) [aioesphomeapi.reconnect_logic] Can't connect to ESPHome API for co2schlafzimmer @ 192.168.178.221: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.178.221', port=6053))]: [Errno 113] Connect call failed ('192.168.178.221', 6053) (SocketAPIError)
2024-04-18 03:20:01.283 WARNING (Thread-9 (_listen)) [homeconnect.sseclient] Exception while reading event:
File "/usr/local/lib/python3.12/site-packages/urllib3/response.py", line 444, in _error_catcher
yield
File "/usr/local/lib/python3.12/site-packages/urllib3/response.py", line 828, in read_chunked
self._update_chunk_length()
File "/usr/local/lib/python3.12/site-packages/urllib3/response.py", line 758, in _update_chunk_length
line = self._fp.fp.readline()
File "/usr/local/lib/python3.12/socket.py", line 707, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.12/ssl.py", line 1252, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.12/ssl.py", line 1104, in read
return self._sslobj.read(len, buffer)
TimeoutError: The read operation timed out
File "/usr/local/lib/python3.12/site-packages/requests/models.py", line 816, in generate
yield from self.raw.stream(chunk_size, decode_content=True)
File "/usr/local/lib/python3.12/site-packages/urllib3/response.py", line 624, in stream
for line in self.read_chunked(amt, decode_content=decode_content):
File "/usr/local/lib/python3.12/site-packages/urllib3/response.py", line 816, in read_chunked
with self._error_catcher():
File "/usr/local/lib/python3.12/contextlib.py", line 158, in __exit__
self.gen.throw(value)
File "/usr/local/lib/python3.12/site-packages/urllib3/response.py", line 449, in _error_catcher
raise ReadTimeoutError(self._pool, None, "Read timed out.")
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='api.home-connect.com', port=443): Read timed out.
File "/usr/local/lib/python3.12/site-packages/homeconnect/sseclient.py", line 81, in __next__
next_chunk = next(self.resp_iterator)
File "/usr/local/lib/python3.12/site-packages/requests/models.py", line 822, in generate
raise ConnectionError(e)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='api.home-connect.com', port=443): Read timed out.
2024-04-18 03:28:21.389 ERROR (MainThread) [homeassistant.helpers.entity] Update for todo.default_task_calendar_name fails
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 715, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 467, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 462, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.12/http/client.py", line 1423, in getresponse
response.begin()
File "/usr/local/lib/python3.12/http/client.py", line 331, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.12/http/client.py", line 300, in _read_status
raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 486, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.12/site-packages/urllib3/connectionpool.py", line 799, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.12/site-packages/urllib3/util/retry.py", line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.12/site-packages/urllib3/packages/six.py", line 769, in reraise
raise value.with_traceback(tb)
response.begin()
urllib3.exceptions.ProtocolError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 951, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1268, in async_device_update
await self.async_update()
File "/usr/src/homeassistant/homeassistant/components/caldav/todo.py", line 115, in async_update
results = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.12/site-packages/caldav/objects.py", line 1079, in search
(response, objects) = self._request_report_build_resultlist(
File "/usr/local/lib/python3.12/site-packages/caldav/objects.py", line 958, in _request_report_build_resultlist
response = self._query(xml, 1, "report")
File "/usr/local/lib/python3.12/site-packages/caldav/objects.py", line 197, in _query
ret = getattr(self.client, query_method)(url, body, depth)
File "/usr/local/lib/python3.12/site-packages/caldav/davclient.py", line 501, in report
return self.request(
File "/usr/local/lib/python3.12/site-packages/caldav/davclient.py", line 596, in request
r = self.session.request(
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 589, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/sessions.py", line 703, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.12/site-packages/requests/adapters.py", line 501, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', RemoteDisconnected('Remote end closed connection without response'))
2024-04-18 03:31:06.133 WARNING (MainThread) [aioesphomeapi.connection] co2kinder @ 192.168.178.195: Connection error occurred: co2kinder @ 192.168.178.195: EOF received
2024-04-18 03:53:46.770 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Timeout fetching Roboter-Staubsauger data
2024-04-18 04:00:00.511 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities button.fritz_box_7590_ui_reconnect are missing or not currently available
2024-04-18 04:00:55.868 ERROR (MainThread) [homeassistant.components.synology_dsm.coordinator] Error fetching 192.168.178.48 SynologyDSMCentralUpdateCoordinator data: Error communicating with API: {'api': None, 'code': -1, 'reason': 'Unknown', 'details': 'ClientError = Bad Gateway'}
2024-04-18 05:00:00.293 WARNING (MainThread) [homeassistant.helpers.service] Referenced entities button.fritz_box_7590_ui_reboot are missing or not currently available
2024-04-18 06:15:21.427 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'RfReceived' when rendering '{{value_json.RfReceived.Data}}'
2024-04-18 06:15:21.493 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'dict object' has no attribute 'RfReceived' (value: {"Time":"2024-04-18T05:15:20","RfRaw":{"Data":"AAA055"}}, template: {{value_json.RfReceived.Data}})
2024-04-18 07:07:34.611 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.browser_mod.media_player.BrowserModPlayer'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <MediaPlayerEntityFeature.PAUSE|SEEK|VOLUME_SET|VOLUME_MUTE|TURN_ON|TURN_OFF|PLAY_MEDIA|STOP|PLAY|BROWSE_MEDIA: 152463>, please report it to the author of the 'browser_mod' custom integration and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-04-18 07:08:55.372 ERROR (MainThread) [custom_components.weenect] Error fetching weenect data: Timeout occurred while connecting to the weenect API.
2024-04-18 07:08:58.461 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-04-18 07:08:58.461 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-04-18 07:08:58.461 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-04-18 07:08:58.461 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-04-18 07:08:58.462 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-04-18 07:08:58.462 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-04-18 07:08:58.462 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-04-18 07:08:58.462 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-04-18 07:08:58.462 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-04-18 07:08:58.462 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-04-18 07:08:59.848 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data:
2024-04-18 07:09:00.634 ERROR (MainThread) [homeassistant.components.hassio.data] Error fetching hassio data: Error on Supervisor API:
2024-04-18 07:14:11.847 ERROR (MainThread) [homeassistant.helpers.template] Template variable error: 'dict object' has no attribute 'RfReceived' when rendering '{{value_json.RfReceived.Data}}'
2024-04-18 07:14:11.905 ERROR (MainThread) [homeassistant.helpers.template] Error parsing value: 'dict object' has no attribute 'RfReceived' (value: {"Time":"2024-04-18T06:14:10","RfRaw":{"Data":"AAA055"}}, template: {{value_json.RfReceived.Data}})
2024-04-18 08:04:12.676 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-04-18 08:04:16.056 WARNING (MainThread) [homeassistant.components.mqtt.discovery] Received message on illegal discovery topic 'homeassistant/sensor/miscale/Baby Sally/config'. The topic contains not allowed characters. For more information see https://www.home-assistant.io/integrations/mqtt/#discovery-topic
2024-04-18 08:04:24.762 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Timeout fetching Roboter-Staubsauger data
2024-04-18 09:35:33.592 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-04-18 09:35:36.844 WARNING (MainThread) [aioesphomeapi.connection] co2schlafzimmer @ 192.168.178.221: Connection error occurred: [Errno 32] Broken pipe
2024-04-18 09:35:37.160 WARNING (MainThread) [homeassistant.components.mqtt.discovery] Received message on illegal discovery topic 'homeassistant/sensor/miscale/Baby Sally/config'. The topic contains not allowed characters. For more information see https://www.home-assistant.io/integrations/mqtt/#discovery-topic
2024-04-18 09:35:38.919 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 88, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 236, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 32, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 53, in get
return await WebSocketHandler(request.app[KEY_HASS], request).async_handle()
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 286, in async_handle
await wsock.prepare(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 152, in prepare
payload_writer = await super().prepare(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 417, in prepare
return await self._start(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 425, in _start
await self._write_headers()
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 505, in _write_headers
await writer.write_headers(status_line, self._headers)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 130, in write_headers
self._write(buf)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 75, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
2024-04-18 10:33:35.445 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Timeout fetching Roboter-Staubsauger data
2024-04-18 10:33:38.294 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for calendar.ics (<class 'custom_components.waste_collection_schedule.calendar.WasteCollectionCalendar'>) took 0.595 seconds. Please report it to the author of the 'waste_collection_schedule' custom integration
2024-04-18 10:33:42.787 WARNING (MainThread) [zigpy_deconz.zigbee.application] Unexpected transmit confirm for request id 95, Status: TXStatus.SUCCESS
2024-04-18 11:01:37.563 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-04-18 11:01:42.161 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 715, in ping
await self._send_frame(message, WSMsgType.PING)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 682, in _send_frame
self._write(header + message)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 702, in _write
2024-04-18 11:01:42.517 WARNING (MainThread) [aioesphomeapi.connection] bluetooth @ 192.168.178.58: Connection error occurred: bluetooth @ 192.168.178.58: EOF received
2024-04-18 11:01:42.938 WARNING (MainThread) [homeassistant.components.mqtt.discovery] Received message on illegal discovery topic 'homeassistant/sensor/miscale/Baby Sally/config'. The topic contains not allowed characters. For more information see https://www.home-assistant.io/integrations/mqtt/#discovery-topic
2024-04-18 12:09:05.290 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-04-18 12:09:08.651 WARNING (MainThread) [aioesphomeapi.connection] co2schlafzimmer @ 192.168.178.221: Connection error occurred: [Errno 32] Broken pipe
2024-04-18 12:09:09.564 WARNING (MainThread) [homeassistant.components.mqtt.discovery] Received message on illegal discovery topic 'homeassistant/sensor/miscale/Baby Sally/config'. The topic contains not allowed characters. For more information see https://www.home-assistant.io/integrations/mqtt/#discovery-topic
2024-04-18 12:34:26.301 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for binary_sensor.wohnzimmer_motion_sensor_belegung (<class 'homeassistant.components.zha.binary_sensor.Occupancy'>) took 0.703 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-18 13:05:36.428 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-04-18 13:05:43.271 WARNING (MainThread) [aioesphomeapi.connection] co2schlafzimmer @ 192.168.178.221: Connection error occurred: [Errno 32] Broken pipe
2024-04-18 13:05:43.340 WARNING (MainThread) [aioesphomeapi.connection] bluetooth @ 192.168.178.58: Connection error occurred: bluetooth @ 192.168.178.58: EOF received
2024-04-18 13:05:43.361 WARNING (MainThread) [aioesphomeapi.connection] co2kinder @ 192.168.178.195: Connection error occurred: co2kinder @ 192.168.178.195: EOF received
2024-04-18 13:05:43.379 WARNING (MainThread) [homeassistant.components.mqtt.discovery] Received message on illegal discovery topic 'homeassistant/sensor/miscale/Baby Sally/config'. The topic contains not allowed characters. For more information see https://www.home-assistant.io/integrations/mqtt/#discovery-topic
2024-04-18 13:05:46.473 ERROR (MainThread) [custom_components.weenect] Error fetching weenect data: Timeout occurred while connecting to the weenect API.
2024-04-18 13:10:35.034 WARNING (Thread-9 (_listen)) [homeconnect.sseclient] Exception while reading event:
StopIteration
2024-04-18 13:42:20.318 WARNING (Thread-2 (_thread_main)) [homeassistant.components.mqtt.client] Disconnected from MQTT server core-mosquitto:1883 (7)
2024-04-18 13:42:25.484 WARNING (MainThread) [homeassistant.components.mqtt.discovery] Received message on illegal discovery topic 'homeassistant/sensor/miscale/Baby Sally/config'. The topic contains not allowed characters. For more information see https://www.home-assistant.io/integrations/mqtt/#discovery-topic
2024-04-18 13:42:27.233 WARNING (MainThread) [aioesphomeapi.connection] bluetooth @ 192.168.178.58: Connection error occurred: bluetooth @ 192.168.178.58: EOF received
2024-04-18 13:42:27.246 WARNING (MainThread) [aioesphomeapi.connection] co2kinder @ 192.168.178.195: Connection error occurred: co2kinder @ 192.168.178.195: EOF received
2024-04-18 13:42:27.246 WARNING (MainThread) [aioesphomeapi.connection] co2schlafzimmer @ 192.168.178.221: Connection error occurred: co2schlafzimmer @ 192.168.178.221: EOF received
2024-04-18 13:42:28.547 ERROR (MainThread) [aiohttp.server] Error handling request
self._write(buf)
You have a bad custom component (scheduler) that is causing HA to crash. Delete it.
