Home Assistant restarts every 30 to 60 minutes
Hey,
I am pretty new to home assistant and thought the easiest (and most robust) way would be to use Hass.io. Unfortunately, my system seems to be restarting every thirty to sixty minutes. Based on my searches, I believe this might be related to the watchdog, but I really have no idea how to a) further debug this and b) fix this.
Help appreciated.
Anyone? This is really annoying and makes this much less useful. Plus, it also corrupted my database yesterday.
Maybe a bad SD-Card.
I had same issues with homebridge in ha 60.1 so i updated to 63.0 and disabled homebridge and downgraded to ha 60.1 and not use homebridge now… i wish you solve this problem.
I have had random restart issues on my Raspberry Pi in the past because of a power supply that was operating on the edge of what it could deliver. A beefier power supply solved the issue. I don’t know if that is applicable to the pattern you experience. My restarts were only a few times a week.
The power supply might be the issue. Do you know how many amps does your power supply provide? For stable operation, you will need at least 2.5 A, however 3A is better. Most phone chargers only output 1A, so if you are using one of those then it’s likely that’s where the problem’s coming from.
Power it was. Thanks to everyone for pointing me into the right direction.
