Home assistant & rpi
hi,
so i currently have a rpi 4 setup for my HA but it doesn’t need alot of resources assigned to it to run. so i was thinking of using my rpi for multiple uses like HA + local webhosting.
obviously i can’t partition a sd card. so I’m wondering is there a way for me to setup a rpi with Debian software and run HA on the same rpi ? if its possible could someone point me in the direction on how to do it ? :slight_smile:
Not advised, but here you find a how-to
Otherwise (better supported) is to use a HA Container installation
