I found the following in dmesg:
[ 1.226831] ata6: SATA link down (SStatus 0 SControl 300)
[ 1.228507] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.230211] ata2.00: ATA-7: QEMU HARDDISK, 2.5+, max UDMA/100
[ 1.231177] ata2.00: 1073741824 sectors, multi 16: LBA48 NCQ (depth 32)
[ 1.232310] ata2.00: applying bridge limits
[ 1.233053] ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[ 1.233802] ata1.00: ATA-7: QEMU HARDDISK, 2.5+, max UDMA/100
[ 1.234435] ata1.00: 419430400 sectors, multi 16: LBA48 NCQ (depth 32)
[ 1.235110] ata1.00: applying bridge limits
[ 1.235823] ata3: SATA link down (SStatus 0 SControl 300)
[ 1.236596] ata4: SATA link down (SStatus 0 SControl 300)
[ 1.237335] ata5: SATA link down (SStatus 0 SControl 300)
[ 1.238032] ata2.00: configured for UDMA/100
[ 1.238605] ata1.00: configured for UDMA/100
[ 1.239208] scsi 0:0:0:0: Direct-Access ATA QEMU HARDDISK 2.5+ PQ: 0 ANSI: 5
[ 1.240128] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 1.240150] sd 0:0:0:0: [sda] 419430400 512-byte logical blocks: (215 GB/200 GiB)
[ 1.240822] scsi 1:0:0:0: Direct-Access ATA QEMU HARDDISK 2.5+ PQ: 0 ANSI: 5
[ 1.241453] sd 0:0:0:0: [sda] Write Protect is off
[ 1.242263] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 1.242286] sd 1:0:0:0: [sdb] 1073741824 512-byte logical blocks: (550 GB/512 GiB)
[ 1.242290] sd 1:0:0:0: [sdb] Write Protect is off
[ 1.242291] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 1.242298] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.242778] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 1.245905] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 1.246380] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 1.250075] sda: sda1 sda2 sda3 sda4 sda5 sda6 sda7 sda8
[ 1.250967] sd 0:0:0:0: [sda] Attached SCSI disk
And the other command:
➜ ~ ls -l /dev/sd*
brw-rw---- 1 root disk 8, 0 Apr 25 09:53 /dev/sda
brw-rw---- 1 root disk 8, 1 Apr 25 09:53 /dev/sda1
brw-rw---- 1 root disk 8, 2 Apr 25 09:53 /dev/sda2
brw-rw---- 1 root disk 8, 3 Apr 25 09:53 /dev/sda3
brw-rw---- 1 root disk 8, 4 Apr 25 09:53 /dev/sda4
brw-rw---- 1 root disk 8, 5 Apr 25 09:53 /dev/sda5
brw-rw---- 1 root disk 8, 6 Apr 25 09:53 /dev/sda6
brw-rw---- 1 root disk 8, 7 Apr 25 09:53 /dev/sda7
brw-rw---- 1 root disk 8, 8 Apr 25 09:53 /dev/sda8
brw-rw---- 1 root disk 8, 16 Apr 25 09:53 /dev/sdb
If I’m understanding these logs correctly, the disk is being detected. How should I mount it?
