So yea, as the title says home assistant is running in safe mode. The log is
Prior to this error, I was attempting to install HACS from https://hacs.xyz/docs/setup/download using wget -O - https://get.hacs.xyz | bash -
The install seemed to go well, but I ran the install twice, after rebooting the second time I was in safe mode? Is this saveable?
Thanks in advance.
2021-10-27 23:13:29 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] mapping values are not allowed here
in "/config/scripts.yaml", line 3, column 34
2021-10-27 23:13:29 ERROR (MainThread) [homeassistant.bootstrap] Failed to parse configuration.yaml: mapping values are not allowed here
in "/config/scripts.yaml", line 3, column 34. Activating safe mode
