I am getting the same issue with trying to do a clean install using 2018-10-27-Hassbian img
It has been driving me absolutely potty. I have a new SD card (SanDisk) and am also behind a double NAT. I have tried the suggestion by @gpbenton but am getting absolutely nowhere.
pi@hassbian:~ $ sudo chown homeassistant:homeassistant /srv/homeassistant
pi@hassbian:~ $ sudo hassbian-config install homeassistant --force
Home Assistant install script for Hassbian.
Copyright(c) 2017 Fredrik Lindqvist https://github.com/Landrash.
Changing to the homeassistant user
Creating Home Assistant venv
Changing to Home Assistant venv
Installing latest version of Home Assistant
Requirement already satisfied: setuptools in /srv/homeassistant/lib/python3.5/si te-packages
Collecting wheel
Downloading https://files.pythonhosted.org/packages/96/ba/a4702cbb6a3a485239fb e9525443446203f00771af9ac000fa3ef2788201/wheel-0.33.1-py2.py3-none-any.whl
Installing collected packages: wheel
Successfully installed wheel-0.33.1
Collecting homeassistant
Downloading https://files.pythonhosted.org/packages/d2/6d/6ffc1882cc4492ed7f2c 5acb88c6299729f4462c8c86e542c037c659ce36/homeassistant-0.91.4-py3-none-any.whl ( 4.2MB)
Collecting pytz>=2018.07 (from homeassistant)
Downloading https://files.pythonhosted.org/packages/3d/73/fe30c2daaaa0713420d0 382b16fbb761409f532c56bdcc514bf7b6262bb6/pytz-2019.1-py2.py3-none-any.whl (510kB )
Collecting voluptuous-serialize==2.1.0 (from homeassistant)
Exception:
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w hl/urllib3/connectionpool.py”, line 594, in urlopen
chunked=chunked)
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w hl/urllib3/connectionpool.py”, line 391, in _make_request
six.raise_from(e, None)
File “”, line 2, in raise_from
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w hl/urllib3/connectionpool.py”, line 387, in _make_request
httplib_response = conn.getresponse()
File “/usr/lib/python3.5/http/client.py”, line 1198, in getresponse
response.begin()
File “/usr/lib/python3.5/http/client.py”, line 297, in begin
version, status, reason = self._read_status()
File “/usr/lib/python3.5/http/client.py”, line 266, in _read_status
raise RemoteDisconnected(“Remote end closed connection without”
http.client.RemoteDisconnected: Remote end closed connection without response
File “/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py”, line 554, in _prepare_file
require_hashes
File “/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_install.py”, line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/index.py”, line 792, in get_page
“Cache-Control”: “max-age=600”,
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any. whl/requests/sessions.py”, line 501, in get
return self.request(‘GET’, url, **kwargs)
File “/srv/homeassistant/lib/python3.5/site-packages/pip/download.py”, line 38 6, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any. whl/requests/sessions.py”, line 488, in request
resp = self.send(prep, **send_kwargs)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any. whl/requests/sessions.py”, line 609, in send
r = adapter.send(request, **kwargs)
File “/srv/homeassistant/share/python-wheels/CacheControl-0.11.7-py2.py3-none- any.whl/cachecontrol/adapter.py”, line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File “/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any. whl/requests/adapters.py”, line 423, in send
timeout=timeout
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w hl/urllib3/connectionpool.py”, line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File “/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.w hl/urllib3/util/retry.py”, line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: ‘Retry’ and ‘int’
Deactivating virtualenv
Enabling Home Assistant service
Disabling the Home Assistant install script
Starting Home Assistant
Checking the installation…
Installation failed…
If you have issues with this script, please say something in the #devs_hassbian channel on Discord.
