Home assistant service not starting on new hassbian install
I downloaded image_2018-10-27-Hassbian and used etcher to put it on a 16gig samsung class 10 microsd. When I boot it in my pi 3 B it gets to the login and after waiting at least 30 minutes and trying this a few times (re-etching, formating the sd with diskpart and re-etching) , it never starts the home assistant service.
I did this:
If you find that the web page is not reachable after 30 minutes or so, check that you have files in /home/homeassistant/.homeassistant/ , if there are no files in this location then run the installer manually using this command: sudo systemctl start install_homeassistant.service .
and there are no files and it wonā€™t download them either. Iā€™m connected to my network with ethernet and can ssh in. I can ping google fine. I also didnā€™t have a problem running and installing hassio previously.
I just canā€™t get it to download homeassistant. I copy paste this exact command ā€œsudo systemctl start install_homeassistant.serviceā€ and it does something for a few seconds and then goes back to the command prompt. No files are in the /home/homeassistant directory
Iā€™ve had hassio running on this pi 3 b but want to use hassbian instead.
It should work but doesnā€™t. Iā€™m not well versed enough to know if/what log in var/logs would tell me something
Any hints/tips/pointers would be greatly appreciated
Can you paste the output of
systemctl status [email protected]
and
ls -alR /home/homeassistant/.homeassistant/
pi@hassbian:~ $ systemctl status [email protected]
ā— [email protected] - Home Assistant for homeassistant
Loaded: loaded (/etc/systemd/system/[email protected]; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2018-11-09 17:17:59 UTC; 9min ago
Process: 1251 ExecStart=/srv/homeassistant/bin/hass (code=exited, status=203/EXEC)
Main PID: 1251 (code=exited, status=203/EXEC)
Nov 09 17:17:59 hassbian systemd[1]: Started Home Assistant for homeassistant.
Nov 09 17:17:59 hassbian systemd[1]: [email protected]: Main process exited, code=exited, status=203/EXEC
Nov 09 17:17:59 hassbian systemd[1]: [email protected]: Unit entered failed state.
Nov 09 17:17:59 hassbian systemd[1]: [email protected]: Failed with result ā€˜exit-codeā€™.
and
ls: cannot access ā€˜/home/homeassistant/.homeassistant/ā€™: No such file or directory
I tried formatting with sdformatter and using diskimager32 this time and now it started and said
services:
home-assistant@homeassistant: inactive (the messages above are from this new try at install)
instead of failed
Iā€™m sorry if I formatted this message wrong.
Just doesnā€™t seem to want to download or put things in the homeassistant directory. I thought this image had the download already? But what do I knowā€¦
Itā€™s very odd.
Edit I did try to start the download manually again but it does the same thing, sits for 3-5 seconds then goes back to the prompt, no messages.
It looks like you may have had some connection issues on first boot, try to run this sudo hassbian-config install homeassistant --force
pi@hassbian:/ $ sudo hassbian-config install homeassistant --force
Home Assistant install script for Hassbian.
Copyright(c) 2017 Fredrik Lindqvist https://github.com/Landrash.
Changing to the homeassistant user
Creating Home Assistant venv
Error: [Errno 13] Permission denied: ā€˜/srv/homeassistant/includeā€™
Changing to Home Assistant venv
/bin/bash: line 6: /srv/homeassistant/bin/activate: No such file or directory
Installing latest version of Home Assistant
File ā€œ/usr/bin/pip3ā€, line 9, in
from pip import main
ImportError: cannot import name ā€˜mainā€™
Deactivating virtualenv
/bin/bash: line 13: deactivate: command not found
Enabling Home Assistant service
Disabling the Home Assistant install script
Starting Home Assistant
Checking the installationā€¦
Installation failedā€¦
For the heck of i tried
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
It downloaded a few things but not enough to make HA install, if that was even part of the problem.
This is the first thing that goes wrong - and it is odd. Can you post the output of
ls -l /srv
just to see what the permissions on the directory is now.
pi@hassbian:~ $ ls -l /srv
total 4
drwxr-xr-x 3 root root 4096 Nov 9 17:10 homeassistant
Iā€™m not sure how it got those permissions, but is should be possible to fix it with
sudo chown homeassistant:homeassistant /srv/homeassistant
This is all very odd though.
Thats the ticket! I can assure you I never messed with any permissions, so yes, it is odd as heck. Iā€™m expecting my shiny new 128gb uh3 sdcard tomorrow and if it works without having to chown, Iā€™ll update here.
But that worked, it installed, took about 10 minutes before I could access the create account page (as expected) and now I poke and prod and learn the intricacies of HA.
Thank you very much!
Why does HA hate me so much? I tried to setup my new sdcard and had to chown again but this time the install fails differently. I even tried repeating other steps like sudo apt-get update and sudo apt-get upgrade but now I am stuck getting this:
    pi@hassbian:~ $ sudo chown homeassistant:homeassistant /srv/homeassistant
pi@hassbian:~ $ sudo hassbian-config install homeassistant --force
Copyright(c) 2017 Fredrik Lindqvist <https://github.com/Landrash>.
Requirement already satisfied: setuptools in /srv/homeassistant/lib/python3.5/site-packages
Requirement already satisfied: wheel in /srv/homeassistant/lib/python3.5/site-packages
Collecting homeassistant
  Using cached https://files.pythonhosted.org/packages/8c/eb/a7d1205eb765eca7f755bc967ae2f79e4d10b20a498a5cef8a82c8e0fc4f/homeassistant-0.82.0-py3-none-any.whl
Collecting pyyaml<4,>=3.13 (from homeassistant)
  Downloading https://www.piwheels.org/simple/pyyaml/PyYAML-3.13-cp35-cp35m-linux_armv7l.whl (42kB)
Collecting cryptography==2.3.1 (from homeassistant)
  Using cached https://www.piwheels.org/simple/cryptography/cryptography-2.3.1-cp35-cp35m-linux_armv7l.whl
Collecting astral==1.7.1 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/bb/0c/25701e9afad088d9873889fba0c45b0fbf8097c7e2ecf8d9b40a71985124/astral-1.7.1-py2.py3-none-any.whl
Collecting voluptuous==0.11.5 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/59/95/fa6218477c6999c9b7fdfab7c12c1bd4da2d5930f5eb2b232ec74eb344e7/voluptuous-0.11.5-py2.py3-none-any.whl
Collecting certifi>=2018.04.16 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/56/9d/1d02dd80bc4cd955f98980f28c5ee2200e1209292d5f9e9cc8d030d18655/certifi-2018.10.15-py2.py3-none-any.whl
Collecting aiohttp==3.4.4 (from homeassistant)
  Using cached https://www.piwheels.org/simple/aiohttp/aiohttp-3.4.4-cp35-cp35m-linux_armv7l.whl
Collecting async-timeout==3.0.1 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/e1/1e/5a4441be21b0726c4464f3f23c8b19628372f606755a9d2e46c187e65ec4/async_timeout-3.0.1-py3-none-any.whl
Requirement already satisfied: pip>=8.0.3 in /srv/homeassistant/lib/python3.5/site-packages (from homeassistant)
Collecting ruamel.yaml==0.15.72 (from homeassistant)
  Using cached https://www.piwheels.org/simple/ruamel-yaml/ruamel.yaml-0.15.72-cp35-cp35m-linux_armv7l.whl
Collecting jinja2>=2.10 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/7f/ff/ae64bacdfc95f27a016a7bed8e8686763ba4d277a78ca76f32659220a731/Jinja2-2.10-py2.py3-none-any.whl (126kB)
Collecting requests==2.20.0 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/f1/ca/10332a30cb25b627192b4ea272c351bce3ca1091e541245cccbace6051d8/requests-2.20.0-py2.py3-none-any.whl
Collecting PyJWT==1.6.4 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/93/d1/3378cc8184a6524dc92993090ee8b4c03847c567e298305d6cf86987e005/PyJWT-1.6.4-py2.py3-none-any.whl
Collecting voluptuous-serialize==2.0.0 (from homeassistant)
  Downloading https://www.piwheels.org/simple/voluptuous-serialize/voluptuous_serialize-2.0.0-py3-none-any.whl
Collecting bcrypt==3.1.4 (from homeassistant)
  Downloading https://www.piwheels.org/simple/bcrypt/bcrypt-3.1.4-cp35-cp35m-linux_armv7l.whl (52kB)
Collecting pytz>=2018.04 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/f8/0e/2365ddc010afb3d79147f1dd544e5ee24bf4ece58ab99b16fbb465ce6dc0/pytz-2018.7-py2.py3-none-any.whl
Collecting attrs==18.2.0 (from homeassistant)
  Using cached https://files.pythonhosted.org/packages/3a/e1/5f9023cc983f1a628a8c2fd051ad19e76ff7b142a0faf329336f9a62a514/attrs-18.2.0-py2.py3-none-any.whl
Collecting idna>=2.1 (from cryptography==2.3.1->homeassistant)
  Downloading https://files.pythonhosted.org/packages/4b/2a/0276479a4b3caeb8a8c1af2f8e4355746a97fab05a372e4a2c6a6b876165/idna-2.7-py2.py3-none-any.whl (58kB)
Collecting six>=1.4.1 (from cryptography==2.3.1->homeassistant)
  Downloading https://files.pythonhosted.org/packages/67/4b/141a581104b1f6397bfa78ac9d43d8ad29a7ca43ea90a2d863fe3056e86a/six-1.11.0-py2.py3-none-any.whl
Collecting asn1crypto>=0.21.0 (from cryptography==2.3.1->homeassistant)
  Downloading https://files.pythonhosted.org/packages/ea/cd/35485615f45f30a510576f1a56d1e0a7ad7bd8ab5ed7cdc600ef7cd06222/asn1crypto-0.24.0-py2.py3-none-any.whl (101kB)
Collecting cffi!=1.11.3,>=1.7 (from cryptography==2.3.1->homeassistant)
  Downloading https://www.piwheels.org/simple/cffi/cffi-1.11.5-cp35-cp35m-linux_armv7l.whl (304kB)
Collecting multidict<5.0,>=4.0 (from aiohttp==3.4.4->homeassistant)
  Downloading https://www.piwheels.org/simple/multidict/multidict-4.4.2-cp35-cp35m-linux_armv7l.whl (373kB)
Collecting yarl<2.0,>=1.0 (from aiohttp==3.4.4->homeassistant)
  Downloading https://files.pythonhosted.org/packages/43/b8/057c3e5b546ff4b24263164ecda13f6962d85c9dc477fcc0bcdcb3adb658/yarl-1.2.6.tar.gz (159kB)
Collecting chardet<4.0,>=2.0 (from aiohttp==3.4.4->homeassistant)
Exception:
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
    chunked=chunked)
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 391, in _make_request
    six.raise_from(e, None)
  File "<string>", line 2, in raise_from
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 387, in _make_request
    httplib_response = conn.getresponse()
  File "/usr/lib/python3.5/http/client.py", line 1198, in getresponse
    response.begin()
  File "/usr/lib/python3.5/http/client.py", line 297, in begin
    version, status, reason = self._read_status()
  File "/usr/lib/python3.5/http/client.py", line 266, in _read_status
    raise RemoteDisconnected("Remote end closed connection without"
http.client.RemoteDisconnected: Remote end closed connection without response
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/commands/install.py", line 353, in run
    wb.build(autobuilding=True)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/wheel.py", line 749, in build
    self.requirement_set.prepare_files(self.finder)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_set.py", line 554, in _prepare_file
    require_hashes
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/req/req_install.py", line 278, in populate_link
    self.link = finder.find_requirement(self, upgrade)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 465, in find_requirement
    all_candidates = self.find_all_candidates(req.name)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 423, in find_all_candidates
    for page in self._get_pages(url_locations, project_name):
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 568, in _get_pages
    page = self._get_page(location)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 683, in _get_page
    return HTMLPage.get_page(link, session=self.session)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/index.py", line 792, in get_page
    "Cache-Control": "max-age=600",
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
    return self.request('GET', url, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/pip/download.py", line 386, in request
    return super(PipSession, self).request(method, url, *args, **kwargs)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
    resp = super(CacheControlAdapter, self).send(request, **kw)
  File "/srv/homeassistant/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
    timeout=timeout
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/srv/homeassistant/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment
    total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
Checking the installation...
Installation failed...
If you have issues with this script, please say something in the #devs_hassbian channel on Discord.
pi@hassbian:~ $
Looks like a network problem.
Seems Iā€™m behind a double nat which Iā€™m not certain I can get rid of. I was able to dmz the pi and I just finished the install.
Installation done..
Your Home Assistant installation is running at 192.168.1.226:8123 or if preferred http://hassbian.local:8123
I have the exact same issue. Downloaded image_2018-10-27-Hassbian, burned it an Sandisk card with Etcher and booted up on the RPi 3+ just fine. No home assistant running, even after a while.
Checked the directory as in this thread and it had the same permissions for root only.
Ran the chown command and restarted the setup and itā€™s moving along nicely now.
//Matt
I have the same issue as well:
64GB Sandisk Ultra SD, Raspberry Pi 3B+, image_2018-10-27-Hassbian.zip, had to chown. Ran the install command again and it seems to work now.
Had Hassio running fine on the same SD & RPi before I moved to Hassbian.
I ran into this issue as well. It looks like the install_homeassistant.service does not start properly over wifi. I tried several time using and using systemctl status would show that the service would fail to start.
I flashed a new image and kicked it off connected via wire to Ethernet and everything launched as expected!
Seems like there may be a timing issue where wifi isnā€™t fully connected before the install_homeassistant.service is.
If you are experiencing this issue I would encourage to spin up a freshly flashed SD card and launch when connected via wire.
Iā€™ve run into a similar issue - Iā€™m using a Raspberry Pi B+ (very slow!) but it seems to boot, with the similar timeout issue in the first post - looking through the logs it talks about timing out after getting online (connectivity checked, itā€™s a bit slow but should not cause timeouts, and Iā€™m hardwired to the router). I tried restarting the installer service but it again timed out. After a reboot to just make sure that it was not something else it seems to have deleted itself almost entirely? The homeassistant user does not have a .homeassistant folder, thereā€™s nothing in /srv/ and I canā€™t run hassbian-config (it does not exist) - Iā€™ve tried twice with different SD cards and Iā€™m going to try a fresh install now on top of raspbian lite - fwiw: I managed to get the hassio image to work on this setup but it was just incredibly slow (as you can imagine) - hoping for a minor speed boost by removing some layers of virtualisation.
Hi @zimchaa . Got the same issue on first try today. And
helped me.
In case you try to use homeassistant on top of raspbian - it would be slower rather hasspbian.
Cheers.
Iā€™ve run into the same issue. Iā€™m using a RPI B+ too. The image is image_2018-10-27-Hassbian.zip
After a while, iā€™ve connected to RPI by PuTTY and did some command, ping some webpages (included home-assistant.io) and everything is ok.
But no HA:
  • I tried to access 192.168.0.xxx:8123 in the Chrome but nothing (This site canā€™t be reached).
  • I tried: sudo systemctl start install_homeassistant.service
    but got the error: Failed to start install_homeassistant.service: Unit install_homeassistant.service not found.
  • I tried: sudo hassbian-config install homeassistant --force
    but got the error: sudo: hassbian-config: command not found
I donā€™t know whatā€™s wrong with it? Hope some help.
Thanks very much!
Iā€™ve installed another image image_2018-03-16-Hassbian.zip and itā€™s Ok.
I am having this same damn problem!
First it was the wifi. Then the SD card. Now this error!
How did you ā€œDMZā€ your Pi?
same problem for hassbian 2018-10-27 image. Type your command and it work. Thanks!
