Hi, Im looking to see if anyone has successfully managed to integrate the Sigenergy Inverter and Batteries into Home Assistant with the system connected to the Amber Electric VPP and can still have full control in Home Assistant of the Sigenergy system. I have heard that the systems may fight against each other or Amber will have control over HA.
I have set up the Sigenergy Integration here, which is excellent.
You can also install the Amber Electric Integration which will give you up to date energy prices which should allow you to control the export of your energy.
But im not sure if you get control over battery levels, exporting and importing electricity based on electricty price.
to answer my own question. Yes, it is possible. Use the Amber Integration with the above SigEnergy Integration. You will also need the EMHass Integration and the Solcast Integration. I also followed Brendan’s pages on how to modify the energy management with his script and automations. I modified these to suit my requirements. Here is the link to Brendan’s pages. Running EMHASS | Sigenergy with Home Assistant and EMHASS
Its working great now with more control when required
I’ve started doing this, just havent enabled the battery automation section yet. Just curious, what happened when you turned on the “Remote EMS (Controlled by Home Assistant)” switch? Are you still able to turn on SmartShift in the Amber app? Or do you need to contact them like mentioned in the process? Thanks
