up !?
Anybody has a clue about this ?
up !?
After added intigration from HACS, you need to go to home assistant setting/devices & services/ intigration/ (not HACS intigration), then find and add Nea Singapore weather Intigration.
Is this your Facebook group? Or do you know the moderators? I wanted to join but it looks like I’m blocked, and I have no idea what I might have done wrong.
Where can I buy HA yellow in Singapore?
I would suggest via Seeed Studio
Am definitely interested in this as well. Also anyone knows if the advanced meter rollout is coming anytime soon
Just integrated my mitsubishi aircon with HA using the mitsubishi2mqtt package and Wemos D1 Mini. Works great!
that’s awesome! Which model is your Mitsubishi?
I converted my Mitsubishi2mqtt to ESPHome, as the wifi stack seems weak (frequent unavailable state in logs, for 1 second).
Hi, congratulations on setting up your mitsubishi ac. I am not certain on which board to be used. Would you mind sharing the link to esp32 or 8266 board that you purchased?
Hi, just completing my resale renovation and looking for advice concerning integration of city energy möwe branded products with home assistant.
Do they all communicate using the zigbee network, so if I have a sonoff dongle E on ember firmware, it should be fine?
I had ESPHome solution for Mitsubishi Aircon. Seems like most models are supported as long as there is CN105 connector. I asked AC installer to connect after flashing with ESPHome.
I got M5Stack Atom Lite, M5Stack 5cm Grove cable and JST connectors. No soldering required. Just some small screw drivers to pry out the leads from groove connector and insert the leads into JST connector.
