since the last update to 2021.1.5 my home-assistant is not reliable anymore as it was before. I’m running it on a RPI4 on a supervised OS.
I can see that data processing is stopped, as the graphs are not updated anymore. Also automations do not trigger anymore. But my node-red automations still work, as I received the notifications about activities from node-red (using pushover).
These are the last lines of the log from this night before it stopped and before the restart at 08:15:
2021-01-28 17:57:15 WARNING (MainThread) [homeassistant.components.zwave] Z-Wave not ready after 300 seconds, continuing anyway
2021-01-28 23:33:41 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook a0704c90b6076be2ad174faa108829ac61e863376b07807192f9d69b70b3180f from 192.168.20.105
2021-01-29 00:38:41 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook a0704c90b6076be2ad174faa108829ac61e863376b07807192f9d69b70b3180f from 192.168.20.105
2021-01-29 04:12:00 ERROR (Recorder) [homeassistant.components.recorder.util] Error executing query: Couldn't parse datetime string: '173f8bb786b42fc9615c79013add5538'
2021-01-29 04:12:00 ERROR (Recorder) [root] Uncaught thread exception
File "/usr/local/lib/python3.8/threading.py", line 932, in _bootstrap_inner
self.run()
File "/usr/src/homeassistant/homeassistant/components/recorder/__init__.py", line 364, in run
if not purge.purge_old_data(self, event.keep_days, event.repack):
File "/usr/src/homeassistant/homeassistant/components/recorder/purge.py", line 30, in purge_old_data
states = execute(query, to_native=True, validate_entity_ids=False)
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 78, in execute
result = [
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 78, in <listcomp>
result = [
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 80, in <genexpr>
for row in (
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/loading.py", line 100, in instances
cursor.close()
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/langhelpers.py", line 68, in __exit__
compat.raise_(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/util/compat.py", line 182, in raise_
raise exception
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/loading.py", line 80, in instances
rows = [proc(row) for row in fetch]
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/loading.py", line 80, in <listcomp>
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/loading.py", line 579, in _instance
_populate_full(
File "/usr/local/lib/python3.8/site-packages/sqlalchemy/orm/loading.py", line 725, in _populate_full
dict_[key] = getter(row)
ValueError: Couldn't parse datetime string: '173f8bb786b42fc9615c79013add5538'
2021-01-29 04:58:33 WARNING (MainThread) [homeassistant.components.webhook] Received message for unregistered webhook a0704c90b6076be2ad174faa108829ac61e863376b07807192f9d69b70b3180f from 192.168.20.105
2021-01-29 08:05:44 WARNING (MainThread) [homeassistant.helpers.service] Unable to find referenced entities switch.steckdose5
2021-01-29 08:15:48 ERROR (MainThread) [pydeconz.websocket] Client connection error
2021-01-29 08:16:40 WARNING (zeroconf-ServiceBrowser__http._tcp.local.-_googlecast._tcp.local.-_elg._tcp.local.-_Volumio._tcp.local.-_esphomelib._tcp.local.-_dkapi._tcp.local.-_ipp._tcp.local.-_plugwise._tcp.local.-_bond._tcp.local.-_ssh._tcp.local.-_viziocast._tcp.local.-_touch-able._tcp.local.-_daap._tcp.local.-_axis-video._tcp.local.-_nut._tcp.local.-_homekit._tcp.local.-_mediaremotetv._tcp.local.-_spotify-connect._tcp.local.-_wled._tcp.local.-_ipps._tcp.local.-_hap._tcp.local.-_xbmc-jsonrpc-h._tcp.local.-_api._udp.local.-_printer._tcp.local.-_miio._udp.local._287) [zeroconf] Error sending through socket 27
File "/usr/local/lib/python3.8/site-packages/zeroconf/__init__.py", line 2952, in send
bytes_sent = s.sendto(packet, 0, (real_addr, port))
OSError: [Errno 101] Network unreachable
This is how it looks like in a graph. Last data at 04:07, new data at 08:22 after restart:
These are the last lines of the logbook before restart, no entries between 04:11:14 and restart at 08:22
This happens every day, sometimes twice, since the last update to 2021.1.5. Before it was really stable without any issues.
Any ideas where to look at the root cause?
Best regards
Stefan
