Ill try to describe the issue as simply as possible.
Homeassistant loads and initiates successfully but after a while the following exception happens:
2020-07-26 16:37:08 ERROR (MainThread) [homeassistant] Error doing job: Accept failed on a socket
File “C:\Users\dlavr\AppData\Local\Programs\Python\Python38-32\lib\asyncio\proactor_events.py”, line 801, in loop
conn, addr = f.result()
File “C:\Users\dlavr\AppData\Local\Programs\Python\Python38-32\lib\asyncio\windows_events.py”, line 812, in _poll
value = callback(transferred, key, ov)
File “C:\Users\dlavr\AppData\Local\Programs\Python\Python38-32\lib\asyncio\windows_events.py”, line 552, in finish_accept
ov.getresult()
OSError: [WinError 64] The specified network name is no longer available
2020-07-26 16:37:08 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File “C:\Users\dlavr\AppData\Local\Programs\Python\Python38-32\lib\asyncio\windows_events.py”, line 566, in accept_coro
await future
ov.getresult()
After this, any attempt to connect to localhost:8123 gets a “connection refused”. Things revive via a manual restart only.
Version is 0.113.0 but it also happens on previous versions. Network issues are highly unlike to be causing this - same configuration on the same network works perfectly on a Raspberry Pi
Any ideas?
