Hi, i have recently installed Unraid on my old Lenovo pc. Unraid is up and running, but i have a problem when i try to install Home Assistant using a VM.
Not sure if this is the correct place to post this, but hopefully someone smarter than me has allready been trough this.
I have allready checked that i use the correct info, when i make the VM.
Using Xcow2 vm file
Using 2 Cores CPU
RAM: 2048-4096
And have tried using SATA as well as VirtIO as Primary vDisk Bus.
Attached are a picture of my Unraid VM info.
This is where the OS wont boot, it’s stuck in this BIOS shell. I can type Exit and can enter a menu. I have seen someone with a simular problem and they fixed it with disabling Secure Boot. I can’t see a Secure boot option in this menu.( Checked everywhere )
Thanks in advance for any help!
