Home assistant stuck on Preparing home assistant (Blue Dot)
Hi
A few days bevore I tried to install Home Assistant on a raspberry pi 4. The Installation stuck by the blue dot. So I went to a used Intel NUC. Same problem! So I think it is not a Home Assistant problem. What could it be?
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[16:29:12] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
[16:29:13] INFO: Starting local supervisor watchdog...
s6-rc: info: service legacy-services successfully started
23-02-28 16:29:14 INFO (MainThread) [__main__] Initializing Supervisor setup
23-02-28 16:29:14 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, creating a new network
23-02-28 16:29:15 INFO (MainThread) [supervisor.bootstrap] Seting up coresys for machine: generic-x86-64
23-02-28 16:29:15 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attaching to Supervisor ghcr.io/home-assistant/amd64-hassio-supervisor with version 2022.12.1
23-02-28 16:29:15 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connecting Supervisor to hassio-network
23-02-28 16:29:15 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.INITIALIZE
23-02-28 16:29:15 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-02-28 16:29:15 INFO (MainThread) [__main__] Setting up Supervisor
23-02-28 16:29:15 INFO (MainThread) [supervisor.api] Starting API on 172.30.32.2
23-02-28 16:29:15 INFO (MainThread) [supervisor.hardware.monitor] Started Supervisor hardware monitor
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.manager] Connected to system D-Bus.
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.agent] Load dbus interface io.hass.os
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.hostname] Load dbus interface org.freedesktop.hostname1
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.logind] Load dbus interface org.freedesktop.login1
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.network] Load dbus interface org.freedesktop.NetworkManager
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.rauc] Load dbus interface de.pengutronix.rauc
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.resolved] Load dbus interface org.freedesktop.resolve1
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.systemd] Load dbus interface org.freedesktop.systemd1
23-02-28 16:29:15 INFO (MainThread) [supervisor.dbus.timedate] Load dbus interface org.freedesktop.timedate1
23-02-28 16:29:15 INFO (MainThread) [supervisor.host.services] Updating service information
23-02-28 16:29:15 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-02-28 16:29:16 INFO (MainThread) [supervisor.host.network] Updating local network information
23-02-28 16:29:16 INFO (MainThread) [supervisor.host.apparmor] Loading AppArmor Profiles: {'hassio-supervisor'}
23-02-28 17:29:16 INFO (MainThread) [supervisor.docker.monitor] Started docker events monitor
23-02-28 17:29:16 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-cli versions: [<AwesomeVersion CalVer '2022.11.0'>]
23-02-28 17:29:16 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0
23-02-28 17:29:16 INFO (MainThread) [supervisor.plugins.cli] Starting CLI plugin
23-02-28 17:29:17 INFO (SyncWorker_0) [supervisor.docker.cli] Starting CLI ghcr.io/home-assistant/amd64-hassio-cli with version 2022.11.0 - 172.30.32.5
23-02-28 17:29:17 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-dns versions: [<AwesomeVersion CalVer '2022.04.1'>]
23-02-28 17:29:17 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1
23-02-28 17:29:17 INFO (MainThread) [supervisor.plugins.dns] Starting CoreDNS plugin
23-02-28 17:29:18 INFO (SyncWorker_1) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/amd64-hassio-dns with version 2022.04.1 - 172.30.32.3
23-02-28 17:29:18 INFO (MainThread) [supervisor.plugins.dns] Updated /etc/resolv.conf
23-02-28 17:29:18 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-audio versions: [<AwesomeVersion CalVer '2022.07.0'>]
23-02-28 17:29:18 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0
23-02-28 17:29:18 INFO (MainThread) [supervisor.plugins.audio] Starting Audio plugin
23-02-28 17:29:18 INFO (SyncWorker_1) [supervisor.docker.audio] Starting Audio ghcr.io/home-assistant/amd64-hassio-audio with version 2022.07.0 - 172.30.32.4
23-02-28 17:29:19 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-observer versions: [<AwesomeVersion CalVer '2021.10.0'>]
23-02-28 17:29:19 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0
23-02-28 17:29:19 INFO (MainThread) [supervisor.plugins.observer] Starting observer plugin
23-02-28 17:29:19 INFO (SyncWorker_1) [supervisor.docker.observer] Starting Observer ghcr.io/home-assistant/amd64-hassio-observer with version 2021.10.0 - 172.30.32.6
23-02-28 17:29:19 INFO (SyncWorker_0) [supervisor.docker.interface] Found ghcr.io/home-assistant/amd64-hassio-multicast versions: [<AwesomeVersion CalVer '2022.02.0'>]
23-02-28 17:29:19 INFO (SyncWorker_1) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0
23-02-28 17:29:19 INFO (MainThread) [supervisor.plugins.multicast] Starting Multicast plugin
23-02-28 17:29:20 INFO (SyncWorker_1) [supervisor.docker.multicast] Starting Multicast ghcr.io/home-assistant/amd64-hassio-multicast with version 2022.02.0 - Host
23-02-28 17:29:20 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-02-28 17:29:26 INFO (MainThread) [supervisor.homeassistant.secrets] Loaded 0 Home Assistant secrets
23-02-28 17:29:26 INFO (SyncWorker_1) [supervisor.docker.interface] No version found for ghcr.io/home-assistant/generic-x86-64-homeassistant
23-02-28 17:29:26 INFO (MainThread) [supervisor.homeassistant.core] No Home Assistant Docker image ghcr.io/home-assistant/generic-x86-64-homeassistant found.
23-02-28 17:29:26 INFO (SyncWorker_0) [supervisor.docker.interface] Attaching to ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
23-02-28 17:29:26 INFO (MainThread) [supervisor.homeassistant.core] Using preinstalled landingpage
23-02-28 17:29:26 INFO (MainThread) [supervisor.homeassistant.core] Starting HomeAssistant landingpage
23-02-28 17:29:26 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulse
23-02-28 17:29:26 INFO (SyncWorker_0) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/generic-x86-64-homeassistant with version landingpage
23-02-28 17:29:26 INFO (MainThread) [supervisor.os.manager] Detect Home Assistant Operating System 9.5 / BootSlot A
23-02-28 17:29:26 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/esphome/home-assistant-addon repository
23-02-28 17:29:26 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/home-assistant/addons repository
23-02-28 17:29:26 INFO (MainThread) [supervisor.store.git] Cloning add-on https://github.com/hassio-addons/repository repository
23-02-28 17:29:31 ERROR (MainThread) [supervisor.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
cmdline: git clone -v --recursive --depth=1 --shallow-submodules https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Could not resolve host: github.com
23-02-28 17:29:31 ERROR (MainThread) [supervisor.store] Can't retrieve data from https://github.com/hassio-addons/repository due to
23-02-28 17:29:31 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.EXECUTE_REMOVE - ContextType.STORE / a0d7b954
23-02-28 17:29:31 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.FATAL_ERROR - ContextType.STORE / a0d7b954
23-02-28 17:29:31 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/5c53de3b/esphome-dev/config.yaml: Service esphome not found @ data['discovery'][0]. Got 'esphome'
23-02-28 17:29:31 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/5c53de3b/esphome-beta/config.yaml: Service esphome not found @ data['discovery'][0]. Got 'esphome'
23-02-28 17:29:31 WARNING (SyncWorker_0) [supervisor.store.data] Can't read /data/addons/git/5c53de3b/esphome/config.yaml: Service esphome not found @ data['discovery'][0]. Got 'esphome'
23-02-28 17:29:31 INFO (MainThread) [supervisor.store] Loading add-ons from store: 24 all - 24 new - 0 remove
23-02-28 17:29:31 INFO (MainThread) [supervisor.addons] Found 0 installed add-ons
23-02-28 17:29:31 INFO (MainThread) [supervisor.backups.manager] Found 0 backup files
23-02-28 17:29:31 INFO (MainThread) [supervisor.discovery] Loaded 0 messages
23-02-28 17:29:31 INFO (MainThread) [supervisor.ingress] Loaded 0 ingress sessions
23-02-28 17:29:31 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.SETUP
23-02-28 17:29:31 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-02-28 17:29:31 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.SETUP
23-02-28 17:29:31 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-02-28 17:29:31 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not running - CoreState.SETUP
23-02-28 17:29:31 INFO (MainThread) [__main__] Running Supervisor
23-02-28 17:29:31 INFO (MainThread) [supervisor.os.manager] Rauc: A - marked slot kernel.0 as good
23-02-28 17:29:31 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor.txt
23-02-28 17:29:31 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
23-02-28 17:29:31 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2023.01.1
23-02-28 17:29:31 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2023.01.1.
23-02-28 17:35:47 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.01.1: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.01.1&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.UPDATE_FAILED - ContextType.SUPERVISOR / None
23-02-28 17:35:47 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2023.01.1: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.01.1&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-02-28 17:35:47 CRITICAL (MainThread) [supervisor.core] Can't update Supervisor! This will break some Add-ons or affect future versions of Home Assistant!
23-02-28 17:35:47 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.INITIALIZE' starting 0 add-ons
23-02-28 17:35:47 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SYSTEM' starting 0 add-ons
23-02-28 17:35:47 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.SERVICES' starting 0 add-ons
23-02-28 17:35:47 INFO (MainThread) [supervisor.core] Skiping start of Home Assistant
23-02-28 17:35:47 INFO (MainThread) [supervisor.addons] Phase 'AddonStartup.APPLICATION' starting 0 add-ons
23-02-28 17:35:47 INFO (MainThread) [supervisor.misc.tasks] All core tasks are scheduled
23-02-28 17:35:47 INFO (MainThread) [supervisor.core] Supervisor is up and running
23-02-28 17:35:47 INFO (MainThread) [supervisor.homeassistant.core] Home Assistant setup
23-02-28 17:35:47 INFO (MainThread) [supervisor.host.info] Updating local host information
23-02-28 17:35:47 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5
23-02-28 17:35:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
23-02-28 17:35:47 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.2.5.
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state CoreState.RUNNING
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.SECURITY/ContextType.CORE
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.NO_CURRENT_BACKUP/ContextType.SYSTEM
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.module] Create new suggestion SuggestionType.CREATE_FULL_BACKUP - ContextType.SYSTEM / None
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.module] Create new issue IssueType.NO_CURRENT_BACKUP - ContextType.SYSTEM / None
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.TRUST/ContextType.SUPERVISOR
23-02-28 17:35:47 INFO (MainThread) [supervisor.host.services] Updating service information
23-02-28 17:35:47 INFO (MainThread) [supervisor.host.network] Updating local network information
23-02-28 17:35:47 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
23-02-28 17:35:47 INFO (MainThread) [supervisor.host.manager] Host information reload completed
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_FAILED/ContextType.DNS_SERVER
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.PWNED/ContextType.ADDON
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.DNS_SERVER_IPV6_ERROR/ContextType.DNS_SERVER
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.FREE_SPACE/ContextType.SYSTEM
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.checks.base] Run check for IssueType.IPV4_CONNECTION_PROBLEM/ContextType.SYSTEM
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.check] System checks complete
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
23-02-28 17:35:47 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
23-02-28 17:35:47 INFO (MainThread) [supervisor.jobs] 'ResolutionFixup.run_autofix' blocked from execution, system is not healthy - supervisor
23-02-28 17:41:53 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.2.5&fromImage=ghcr.io%2Fhome-assistant%2Fgeneric-x86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-02-28 17:41:53 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-02-28 17:42:23 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5
23-02-28 17:42:23 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.2.5.
23-02-28 17:47:59 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.2.5&fromImage=ghcr.io%2Fhome-assistant%2Fgeneric-x86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-02-28 17:47:59 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-02-28 17:48:29 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5
23-02-28 17:48:29 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.2.5.
23-02-28 17:54:05 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.2.5&fromImage=ghcr.io%2Fhome-assistant%2Fgeneric-x86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-02-28 17:54:05 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-02-28 17:54:35 INFO (SyncWorker_0) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5
23-02-28 17:54:35 INFO (SyncWorker_0) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.2.5.
23-02-28 18:00:11 ERROR (SyncWorker_0) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.2.5&fromImage=ghcr.io%2Fhome-assistant%2Fgeneric-x86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-02-28 18:00:11 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-02-28 18:00:41 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5
23-02-28 18:00:41 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.2.5.
23-02-28 18:06:17 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5: 500 Server Error for http+docker://localhost/v1.41/images/create?tag=2023.2.5&fromImage=ghcr.io%2Fhome-assistant%2Fgeneric-x86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("Get "https://ghcr.io/v2/": net/http: request canceled while waiting for connection (Client.Timeout exceeded while awaiting headers)")
23-02-28 18:06:17 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
23-02-28 18:06:47 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/generic-x86-64-homeassistant:landingpage to ghcr.io/home-assistant/generic-x86-64-homeassistant:2023.2.5
23-02-28 18:06:47 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/generic-x86-64-homeassistant with tag 2023.2.5.
Can somebody help me?
Have you read this post?
Thank you for the quick reply. This is very interesting but it doesn’t work for me. I think I have an other problem. I am sharing my internet with my neighbor and I have cascading routers. I think there is the problem. Now I have to figure out how to configure my router to hopefully get rid of my problem.
By the way… Why I have this DNS Problem? Home assistant is a local server and my local network is functional for years without any problems.
