[supervisor.resolution.check] Starting system checks with state running
[supervisor.resolution.checks.base] Run check for free_space/system
[supervisor.resolution.checks.base] Run check for security/core
[supervisor.resolution.checks.base] Run check for trust/supervisor
[supervisor.resolution.checks.base] Run check for docker_config/system
[supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
[supervisor.resolution.checks.base] Run check for no_current_backup/system
[supervisor.resolution.module] Create new suggestion create_full_backup - system / None
[supervisor.resolution.module] Create new issue no_current_backup - system / None
[supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
[supervisor.host.services] Updating service information
[supervisor.host.network] Updating local network information
[supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
[supervisor.resolution.checks.base] Run check for pwned/addon
[supervisor.resolution.checks.base] Run check for multiple_data_disks/system
[supervisor.resolution.check] System checks complete
[supervisor.resolution.evaluate] Starting system evaluation with state running
[supervisor.host.sound] Updating PulseAudio information
[supervisor.host.manager] Host information reload completed
[supervisor.resolution.evaluate] System evaluation complete
[supervisor.resolution.fixup] Starting system autofix at state running
[supervisor.resolution.fixup] System autofix complete
The guide is definitely meant for folks that are already semi-familiar with the VM solution they’re running.
I would just delete the VM and start over. These instructions should help better.
If you have USB devices that you’d like to have persistently connected (e.g. ZigBee/Z-Wave sticks) then, before starting the VM, when at the step to enable efi, jump down to this post:
Anyway, as a newbie, the HA system is at least complicated and not very intuitive.
In order to edit the config.yaml you have to install an add-on, really???
Second, I’m trying to add a switch button sync via mqtt broker with an arduino device…no chance to make it run…everyting is complicated and very “non-intuitive”. I used before nodered and the same “sync button” took me 30min when I make it for the first time…same functionality I could not implementd on HA after 3h
