Home Assistant Supervised how to add --device to docker
After several years I have decided to just start completely fresh and installed an ubuntu 18.04 LTS base and followed the alternative install instructions here.
I have stumbled before configuring anything when trying to add a --device to the docker.
I have added portainer and thought about trying to convert it all to a docker-compose setup or a portainer stack but will editing the homeassistant container break the supervised install?
How do I add a --device ?
What device do you want to add ? Z-wave and zigbee sticks should just map through.
It is a wyze usb hub.
Conbee II has passed straight through.
If everything passes through by default I will investigate the underlying OS. There is this warning on the component.
WARNING: This component does not work on Mac OSX, Synology DSM, or other OSs that don’t have hidraw drivers.
Swapping ports and a few restarts later it has shown up but I am not exactly confident yet. I may switch to a docker compose on debian or even just use the NUC image.
