Hello there!
I am not that familiar with Home Assistant and its implementation into docker, but it seems I have installed the Home Assistant Agent and trying to install Home Assistant Supervised.
Does anybody has any idea what am I doing wrong?!
Hello there!
Well you need to be running debian, then you need to follow the instructions. Portainer is not part of the instructions.
Also, it is not recommended install method for rpi.
What is homeassistant agent? Never heard of it.
Start over, install HA OS. Unless you have some very specific use case that requires having the underlying OS available, HA OS is the best option for an Rpi.
I think he means the OS Agent.
